Throttle Body Rebuild, Pictorial |
ctc911ctc |
Mar 25 2019, 09:05 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
My 17 year old son and I have about 9 months into this project. Our first car, working together. Real 'encounter session'. We have the car running with many learning-experiences along the way.
1. Brake Cylinder - weird installation method, on our 3rd re-try, when will it stop leaking? 2. Valve adjustment - third time was a charm - man can this thing make noise! 3. Pedal assem - Seems OK.......then: let's take it apart and make it smoother. 4. Transmission linkage - All seems in Order, what are those bushings??? Hhhm, rebuild 5. Throttle Control - seems sticky, let's rebuild it! 911Rubber! Pretty rough looking after 45+ years Looks pretty grimy down there Had to chisel this out of the degreaser! Circuit Card has 20K and 45 years....REPLACE! All of the parts ready and accounted for,,,,,,,,perhaps we should buy a parts tumbler? Ready to bolt back into the Silver Beast! Big difference from where we started Attached thumbnail(s) |
ctc911ctc |
Mar 25 2019, 09:14 AM
I would like to add that I am trying to figure out the best method to clean parts. Currently we are using degreaser and then various wire brushes (steel and synth) which is less than optimum. Comments welcome!
Mark Henry |
Mar 25 2019, 07:10 PM
I would like to add that I am trying to figure out the best method to clean parts. Currently we are using degreaser and then various wire brushes (steel and synth) which is less than optimum. Comments welcome! I use pinesol great on the aluminum , but don't use it on the brass it doesn't hurt it but turns it black, also pinesol will strip cad plating. |
Lo-Fi Version | Time is now: 24th May 2024 - 10:58 PM |
