#9 Fuse blows, Almost hate to ask about this one. |
dgraves |
Apr 1 2019, 05:46 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
None of my instruments are working. Car starts and runs fine. I did only the following since everything was perfect.
1 - Replaced my flasher relay 2 - Replaced my heater blower motor relay 3 - Checked my heater lever for connectivity by pulling out of the tunnel and replacing. When the fuse blew the first time, I didn't know it was the fuse. So naturally I started checking my dash lights by turning the knob. Nothing. I replaced the fuse once. The gauges appeared to come on. I then noticed the fuel gauge was reading inaccurately full because before the malfunction it was accurately reading that the car was low on fuel. I turned light knob again...and pop, the fuse blew. I have a feeling this is going to be like looking for a needle in a hay stack. Any suggestions? |
Apr 1 2019, 09:07 PM
Does the fuse still pop if you don't turn the headlight knob? If not, then your strongest suspect is the instrument illumination circuit.
I have had a few things that caused that fuse to pop. One was a body shop plugging in the license plate lights the wrong way around. There is a ground tab specifically, and it has continuity through the mounting screw threads. Another was a fuse panel that shifted; there was only one mounting screw in it for a while and it would shift occasionally and short one of the wires plugged into the panel to the panel holder. --DD |
Lo-Fi Version | Time is now: 18th May 2024 - 04:08 PM |
