Misc 914 parts |
Misc 914 parts |
Pdr1787 |
Apr 2 2019, 12:15 AM
Sneaky Pete Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California |
Here are a bunch of misc. parts for sale. for asking price or better offer
Spark plug wires 8mm ...... 60 *Sold* Original belt restraints ( non retractable )...... 50 *Sold* Rocker-arm hardware (Shaft/springs/nuts/bolts/washers)...... 50 *Sold* Outside door handle ..... 50 *Sold* Speaker cover and speaker ( Driver and Passenger side) ...... 100 Heat exchanger elbow .... 50 Heater control valve flap box ....... 50 Clutch release bearing and fork ...... 150 70-72 complete linkage 80 *Sold* Sideshift linkage rod firewall to transmission...... 150 *Sold* Heater blower fan assembly..... 70 70-72 engine motor mount cross bar...... 50 Foot well foam insert ....... 35 Arm rest pocket and lid cover....... 50 Valve cover pair ........ 60 Shifter assembly ...... 100 *Sold* Shift rod coupler 73-76..... 60 w/bolt/screw.....80 *Sold* Motor support bracket 70-72........ 50 Motor mounts...... pair 40 Clutch cable deflection roller and reverse bracket.......40 *Sold* 2.0l cylinders 4 ............ 180 *Sold* Thermostat...... 80 1.7l ecu Works ....... 80 1.7 rods .... 40 Bosch 1.7distributor with vacuum advance..... 100 Hydraulic lifters 1.7 ......80 Vacuum pressure regulator ...... 80 Porsche valve springs full set 90110590150 ...... 140 Bosch starter .......... 140 Bosch 12volt coil ......50 Bosch 009 chrome .........90 Attached thumbnail(s) |
racingredsc |
Apr 12 2019, 10:54 AM
Newbie Group: Members Posts: 18 Joined: 12-April 13 From: Columbia,SC Member No.: 15,762 Region Association: South East States |
What do the heads fit? I need some for '74 2.0.
Pdr1787 |
Apr 13 2019, 10:06 PM
Pdr1787 |
Apr 15 2019, 05:57 AM
What do the heads fit? I need some for '74 2.0. Heads are 2.0L heads. There is damage to one exhaust stud just so you know. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 09:39 PM |
