Misc 914 parts |
Misc 914 parts |
Pdr1787 |
Apr 2 2019, 12:15 AM
Sneaky Pete Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California |
Here are a bunch of misc. parts for sale. for asking price or better offer
Spark plug wires 8mm ...... 60 *Sold* Original belt restraints ( non retractable )...... 50 *Sold* Rocker-arm hardware (Shaft/springs/nuts/bolts/washers)...... 50 *Sold* Outside door handle ..... 50 *Sold* Speaker cover and speaker ( Driver and Passenger side) ...... 100 Heat exchanger elbow .... 50 Heater control valve flap box ....... 50 Clutch release bearing and fork ...... 150 70-72 complete linkage 80 *Sold* Sideshift linkage rod firewall to transmission...... 150 *Sold* Heater blower fan assembly..... 70 70-72 engine motor mount cross bar...... 50 Foot well foam insert ....... 35 Arm rest pocket and lid cover....... 50 Valve cover pair ........ 60 Shifter assembly ...... 100 *Sold* Shift rod coupler 73-76..... 60 w/bolt/screw.....80 *Sold* Motor support bracket 70-72........ 50 Motor mounts...... pair 40 Clutch cable deflection roller and reverse bracket.......40 *Sold* 2.0l cylinders 4 ............ 180 *Sold* Thermostat...... 80 1.7l ecu Works ....... 80 1.7 rods .... 40 Bosch 1.7distributor with vacuum advance..... 100 Hydraulic lifters 1.7 ......80 Vacuum pressure regulator ...... 80 Porsche valve springs full set 90110590150 ...... 140 Bosch starter .......... 140 Bosch 12volt coil ......50 Bosch 009 chrome .........90 Attached thumbnail(s) |
dan123 |
May 15 2019, 08:16 AM
I'm new here ... Group: Members Posts: 0 Joined: 14-May 19 From: toronto Member No.: 23,124 Region Association: Canada |
how much for the cooling fan?
also, can you pls post a pic of the front of it. thx |
Lo-Fi Version | Time is now: 19th April 2024 - 07:04 AM |
