CHT wire connection |
DTMLGND |
Apr 4 2019, 06:09 PM
Newbie Group: Members Posts: 32 Joined: 6-November 11 From: US Member No.: 13,756 Region Association: Southern California |
JeffBowlsby |
Apr 5 2019, 03:56 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The other end of that single white wire should disappear into the FI wiring harness (which ultimately goes to the ECU).
It is for TS2 (head temp sensor) and its not likely that the engine will start without it connected. It will at least be full on rich...which may explain some of your other symptoms. |
DTMLGND |
Apr 5 2019, 04:32 PM
The other end of that single white wire should disappear into the FI wiring harness (which ultimately goes to the ECU). It is for TS2 (head temp sensor) and its not likely that the engine will start without it connected. It will at least be full on rich...which may explain some of your other symptoms. Thanks Jeff, Here’s another shot showing where the wires coming from. I cannot find a broken wire from any part of the harness wiring from the ECU. |
DTMLGND |
Apr 5 2019, 06:05 PM
The other end of that single white wire should disappear into the FI wiring harness (which ultimately goes to the ECU). It is for TS2 (head temp sensor) and its not likely that the engine will start without it connected. It will at least be full on rich...which may explain some of your other symptoms. Thanks Jeff, Here’s another shot showing where the wires coming from. I cannot find a broken wire from any part of the harness wiring from the ECU. ****UPDATE**** Found the cut wire from the harness peeking out of the sheath!! Reconnected and fired right up. Still a rough idle and need to dial it in. Bigger problem now is that gas/oil dripping on to headers around #3 or #4 cylinders. I’ll have to jack back up to get a better look tomorrow. Gotta let the heavy smoke clear for now!! Progress I suppose (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:32 PM |
