Pploco Sti-defiling a 914, such a BLAST! |
pploco |
Apr 5 2019, 03:47 PM
Chief Toilet Flusher Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains |
I figure its high time to start sharing my subaru conversion progress with y'all. I'm new to the 914 and have been silently lurking on the site gleaning as much knowledge as possible. I'm a few months into the conversion, and decided to gather up my pictures and start sharing.
Several years ago I shoe-horned a turbo subaru 2.0 into a 73 beetle 73 Subaru Conversion I had an ABSOLUTE BLAST flogging that poor little thing. But I quickly learned that the bug was not a very safe platform for a 300hp subaru engine. I could dust anything off the line and actually pull the front wheels off the ground. But it was a scary handful on the freeway. I ended up selling it and have missed that angry little blue bug ever since. I've always loved the 914, and have watched from the fringes as they creep up and up in value. So when two basket cases popped up locally on craigslist, I decided it was time to jump back in and do a proper conversion Lucky for me, I found these on a 2'fer one deal: 74: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1555094918.1.jpg) 73: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554504271.1.jpg) The PO had stuffed a Pontiac v6 in the 73. He totally scabbed the conversion together - especially the cooling. No radiator fan, square tubing for coolant lines - its ugly. Not surprising, he cooked the motor. Then let it sit outside and rust. The interior is in excellent shape, but the rockers, longs, hell hole, and door jams are pretty bad. The 74 had been stripped and "prepped" for paint. His reality of "prepped" boarders on insanity. He was planning a LS conversion but didn't get any further than stripping it down and spraying it with john deere yellow (IMG:style_emoticons/default/barf.gif) It basically came home in boxes. But, I picked them both up for $1500, then sold the 1.7 and trans from the 74 for $1K. Not a bad deal at all. I'm planning to use the 74 as my base. It has some hell hole issues and a few rust spots, but the longs are in pretty good shape and the pan is mostly solid. I'll use the 73 for an interior parts car. Now for a motor porn teaser - This is what I put together last weekend (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-22225-1554500840.3.jpg) |
pploco |
Apr 8 2019, 09:39 AM
I started cutting back to find solid metal. Luckily, the long wasn't bad, and I probably cut more out of the inner fender well than I needed. There was definitely one annoying little corner in the firewall that was a booger to clean up.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554737982.1.jpg) It was nice to see that the inside of the long wasn't completely rotten. I probed with my chisel and body hammer and found a little spot at the bottom of the long. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554737983.2.jpg) But there was solid metal to work with. Sorry for the shady picture.. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554737985.3.jpg) I was relieved to see some factory primer peeking through the sides and bottom. Once I vacuumed all the rust and flake out, it looked pretty good overall. I didn't get a good picture, but just in front of the firewall toward the front of the car is all factory primed metal. I'll have to open up the bottom and weld in a patch, but it should be minimal. My plan is to open it up, clean and scrape and then treat with phospho and some frame wax. |
oldschool |
Apr 15 2019, 02:45 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
I started cutting back to find solid metal. Luckily, the long wasn't bad, and I probably cut more out of the inner fender well than I needed. There was definitely one annoying little corner in the firewall that was a booger to clean up. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554737982.1.jpg) It was nice to see that the inside of the long wasn't completely rotten. I probed with my chisel and body hammer and found a little spot at the bottom of the long. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554737983.2.jpg) But there was solid metal to work with. Sorry for the shady picture.. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554737985.3.jpg) I was relieved to see some factory primer peeking through the sides and bottom. Once I vacuumed all the rust and flake out, it looked pretty good overall. I didn't get a good picture, but just in front of the firewall toward the front of the car is all factory primed metal. I'll have to open up the bottom and weld in a patch, but it should be minimal. My plan is to open it up, clean and scrape and then treat with phospho and some frame wax. (IMG:style_emoticons/default/welcome.png) ..wow I need to do that same job if you are using a chip board template please. (IMG:style_emoticons/default/aktion035.gif) save and sent to me. |
Lo-Fi Version | Time is now: 5th May 2024 - 09:06 PM |
