Pploco Sti-defiling a 914, such a BLAST! |
pploco |
Apr 5 2019, 03:47 PM
Chief Toilet Flusher Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains |
I figure its high time to start sharing my subaru conversion progress with y'all. I'm new to the 914 and have been silently lurking on the site gleaning as much knowledge as possible. I'm a few months into the conversion, and decided to gather up my pictures and start sharing.
Several years ago I shoe-horned a turbo subaru 2.0 into a 73 beetle 73 Subaru Conversion I had an ABSOLUTE BLAST flogging that poor little thing. But I quickly learned that the bug was not a very safe platform for a 300hp subaru engine. I could dust anything off the line and actually pull the front wheels off the ground. But it was a scary handful on the freeway. I ended up selling it and have missed that angry little blue bug ever since. I've always loved the 914, and have watched from the fringes as they creep up and up in value. So when two basket cases popped up locally on craigslist, I decided it was time to jump back in and do a proper conversion Lucky for me, I found these on a 2'fer one deal: 74: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1555094918.1.jpg) 73: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554504271.1.jpg) The PO had stuffed a Pontiac v6 in the 73. He totally scabbed the conversion together - especially the cooling. No radiator fan, square tubing for coolant lines - its ugly. Not surprising, he cooked the motor. Then let it sit outside and rust. The interior is in excellent shape, but the rockers, longs, hell hole, and door jams are pretty bad. The 74 had been stripped and "prepped" for paint. His reality of "prepped" boarders on insanity. He was planning a LS conversion but didn't get any further than stripping it down and spraying it with john deere yellow (IMG:style_emoticons/default/barf.gif) It basically came home in boxes. But, I picked them both up for $1500, then sold the 1.7 and trans from the 74 for $1K. Not a bad deal at all. I'm planning to use the 74 as my base. It has some hell hole issues and a few rust spots, but the longs are in pretty good shape and the pan is mostly solid. I'll use the 73 for an interior parts car. Now for a motor porn teaser - This is what I put together last weekend (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-22225-1554500840.3.jpg) |
pploco |
Oct 7 2019, 09:18 AM
I finally tackled something I've been putting off for a while. The Coldwater cradle sits the drivetrain just a little too far forward - causing the axles to not quite line up. I've been thinking for months on how I could pull everything back about 2 inches to get the axles to line up better. I decided to man up and finish it so I could do some fab work in the engine compartment.
Here's what I started with: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1570461521.1.jpg) I got a strap around the motor and one on the trans, then used the hoist to support the motor, dropped the cradle off and sliced the mount along the bend. Then I flipped the cut flanges and put them back on the motor - pulled the drive train back a bit. I used a super long screwdriver pushed through the hub - which worked perfectly because the rubber grip centered in the splines. Then I positioned the trans axle outputs to line up. I measured the distance between axle output and hubs to ensure I was square, then I tacked the motor mount flanges back to the cradle. Checked my measurements again, and welded them up. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1570461523.2.jpg) I'm not sure why Ian didn't do this in the first place. I'm no engineer, but having the motor weight centered on top of the crossbar seems a lot better. It was actually a much easier fix than I was anticipating. I have a tendency to overthink things like this and obsess on all the different ways to go about it. The hardest part was reworking the trans mounts. I forgot to take pictures after finishing, but they turned out pretty nice. I did have my chopsaw blade bind and explode on me - that sucked. I also had some time to make a better cart for the motor so I can wheel it around the garage and it sits high enough to clear the engine hoist. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1571066027.1.jpg) |
Lo-Fi Version | Time is now: 5th May 2024 - 08:04 PM |
