Pploco Sti-defiling a 914, such a BLAST! |
pploco |
Apr 5 2019, 03:47 PM
Chief Toilet Flusher Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains |
I figure its high time to start sharing my subaru conversion progress with y'all. I'm new to the 914 and have been silently lurking on the site gleaning as much knowledge as possible. I'm a few months into the conversion, and decided to gather up my pictures and start sharing.
Several years ago I shoe-horned a turbo subaru 2.0 into a 73 beetle 73 Subaru Conversion I had an ABSOLUTE BLAST flogging that poor little thing. But I quickly learned that the bug was not a very safe platform for a 300hp subaru engine. I could dust anything off the line and actually pull the front wheels off the ground. But it was a scary handful on the freeway. I ended up selling it and have missed that angry little blue bug ever since. I've always loved the 914, and have watched from the fringes as they creep up and up in value. So when two basket cases popped up locally on craigslist, I decided it was time to jump back in and do a proper conversion Lucky for me, I found these on a 2'fer one deal: 74: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1555094918.1.jpg) 73: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1554504271.1.jpg) The PO had stuffed a Pontiac v6 in the 73. He totally scabbed the conversion together - especially the cooling. No radiator fan, square tubing for coolant lines - its ugly. Not surprising, he cooked the motor. Then let it sit outside and rust. The interior is in excellent shape, but the rockers, longs, hell hole, and door jams are pretty bad. The 74 had been stripped and "prepped" for paint. His reality of "prepped" boarders on insanity. He was planning a LS conversion but didn't get any further than stripping it down and spraying it with john deere yellow (IMG:style_emoticons/default/barf.gif) It basically came home in boxes. But, I picked them both up for $1500, then sold the 1.7 and trans from the 74 for $1K. Not a bad deal at all. I'm planning to use the 74 as my base. It has some hell hole issues and a few rust spots, but the longs are in pretty good shape and the pan is mostly solid. I'll use the 73 for an interior parts car. Now for a motor porn teaser - This is what I put together last weekend (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-22225-1554500840.3.jpg) |
pploco |
May 22 2022, 09:11 AM
I had a few hours to work on the 914 this weekend. I prepped and treated the interior of the long and the sail panel with ZR. I attached a brush to a long stick and got as far up into the rear of the long as I could and did the same forward. Then let it cure for 24 hours.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1653232261.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1653232262.2.jpg) I also hit the spots I knew would be tough or impossible to reach once the sail panel was welded on. My plan is to use ZR in spots that I won't be able to get to with epoxy primer. I made my patch for the lower rear long with two pieces of 16gauge to match the thickness and structure of the existing metal. This has added a few challenges in welding and fabbing the patches, but makes things much easier once the panel is fitted in matching thickness. I still have some cleanup to do, but it turned out better than I hoped. The PO had done some serious hammering to the long - no idea what he was thinking. The top of the long towards the fender was smashed down in the corner. When I repaired the hell hold, I wrapped the top with a piece of 14 gauge and bent it around to reshape it. Its kinda ugly, but the long stiffener kit and fender should cover most of the dents. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1653232262.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1653232263.4.jpg) Once cleaned up, I test fitted the long siffener kit rear piece and it fit perfectly. I was pretty happy until I stripped one of the bolts in the suspension mount taking the piece off. (IMG:style_emoticons/default/headbang.gif) I think I can just run a chase through it, but makes me kinda mad. Finally, I welded and cleaned up some of the sail panel replacement. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1653232263.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22225-1653232263.6.jpg) I still have a few spot welds and some cleanup and pinholes to fix, but I ran out of welding gas so I called it a night. Getting this phase completed felt like a milestone. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:26 PM |
