SOLD -- 1974 with Raby 2270 Performer, Updated November 2019 |
zx-niner |
Apr 8 2019, 08:09 AM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
11/23/2019 Car has been sold.
For sale 1974 model with a Raby turnkey 2270, Tangerine exhaust, full instrumentation, working A/C, rebuilt suspension and brakes, new seat upholstery with heated seats. All the right parts, done right, but needs some cosmetic work inside and out to make perfect. Located in Las Vegas but current registration in California. Steve sfrnkwch@yahoo.com |
zx-niner |
Apr 8 2019, 01:48 PM
Now for the things that aren't so pretty.
First and foremost are the bubbles near the driver door handle. They have been there since I got the car in 2008 and do not have appeared to have changed at all. I have always kept the car garaged and dry. A previous owner must have had different side view mirrors installed as there are some holes drilled on each door. A rubber washer seals each hole. Rush in the battery tray is a relatively new development, probably from the cars storage from 2011 to 2017. You can see the battery tray in an earlier picture that is was pristine. The corrosion is only limited to the tray bottom and has not affected the side weld or underneath support. Two normal areas of rust that are NOT affected are the side longitudinals and the hell hole. Sorry, I only have a photo of the right side longitudinal exposed, and no longer have a floor jack or stands (or gumption) to remove the left side panel. Also, that is fire extinguisher foam in the hell hole which will be explained in a future post. |
Lo-Fi Version | Time is now: 25th April 2024 - 05:39 AM |
