Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,194 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 973 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
would it make sense to have two levels, one for running / daytime and one for night time use. the heat for daytime running would be decreased . AL
Spoke |
would it make sense to have two levels, one for running / daytime and one for night time use. the heat for daytime running would be decreased . AL It is possible to do that. Also most LED drivers have an input to dim or decrease the current. By putting a negative temperature coefficient resistor on the input, the current can be decreased by an increase in temperature. |
Lo-Fi Version | Time is now: 18th July 2025 - 06:49 PM |
