LED Foglight Project |
Spoke |
Apr 13 2019, 08:45 AM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. This is the spectral dispersion for the lens. |
Spoke |
Apr 29 2019, 01:55 PM
Things like this happen when you set the temperature profile wrong on the infrared oven.
@mepstein I have your foglight board. Not sure why it doesn't light up but I'm working on that. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
mepstein |
Apr 29 2019, 02:14 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Things like this happen when you set the temperature profile wrong on the infrared oven. @mepstein I have your foglight board. Not sure why it doesn't light up but I'm working on that. (IMG:style_emoticons/default/beerchug.gif) That looks more like when I try to do electrical work. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:16 AM |
