> LED Foglight Project
Spoke
post Apr 13 2019, 08:45 AM
Jerry
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight.
Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below.
This is the spectral dispersion for the lens.
JeffBowlsby
post May 7 2019, 06:55 PM
Open the housing and disconnect the wires! No cutting allowed!
Spoke
post May 8 2019, 08:02 PM
Jerry
QUOTE(JeffBowlsby @ May 7 2019, 08:55 PM) *
Agreed. My LED boards are designed to be plug'n'play without cutting the vehicle wiring using the existing bulb plug to power the LEDs. An exception to that are the Triumph Spitfire and TR6 where the bulb sockets are so unreliable that LED boards connect directly to the wire loom bypassing the bulb socket.
For the 914 foglight, there's not much play in the wiring at the foglight fixture. I didn't think there was a connector for the the fogs inside the trunk. One issue is the condition of the ground spade connector. The one foglight fixture from Mark the ground spade was rusted onto the lug on the fixture. For the foglight the original bulb socket will not be used as the reflector and bulb socket are not used with the LEDs.
I'll make it work with the existing wires.
Spoke   LED Foglight Project   Apr 13 2019, 08:45 AM
Spoke   The LEDs will be connected in series and driven by...   Apr 13 2019, 08:51 AM
Spoke   This is what the board looks like right now. It ma...   Apr 13 2019, 08:58 AM
mepstein   I don't understand any of this but it sure loo...   Apr 13 2019, 12:16 PM
StratPlayer   Will you be making these for the rectangle style f...   Apr 13 2019, 01:34 PM
Spoke   Will you be making these for the rectangle style ...   Apr 14 2019, 05:57 AM
Spoke   Will you be making these for the rectangle style ...   May 9 2019, 07:24 PM
mepstein   [quote name='StratPlayer' post='2704950' date='Ap...   May 9 2019, 07:37 PM
DRPHIL914   [quote name='StratPlayer' post='2704950' date='Ap...   May 10 2019, 08:13 AM
Luke M   I'd be in for an early set once you get them d...   Apr 13 2019, 02:11 PM
914-300Hemi   Looks great Spoke.   Apr 14 2019, 06:05 AM
Spoke   This is the fixture I'll use to size the board...   Apr 14 2019, 06:09 AM
Spoke   I printed the PCB front and bottom sides since I c...   Apr 14 2019, 06:15 AM
Spoke   With the spacer attached, now the PCB can sit squa...   Apr 14 2019, 06:21 AM
Tbrown4x4   I'm totally supporting this. I drive at night ...   Apr 14 2019, 07:09 AM
mepstein   I'm totally supporting this. I drive at night...   Apr 14 2019, 10:45 AM
mb911   Really excited for this although currently I only ...   Apr 14 2019, 09:27 AM
mepstein   Really excited for this although currently I only...   Apr 14 2019, 10:33 AM
Tbrown4x4   Good to know! I think I have these on an Amazo...   Apr 15 2019, 05:02 AM
orthobiz   This is great, thanks. I posted some lens pictures...   Apr 15 2019, 03:31 PM
Spoke   This is great, thanks. I posted some lens picture...   Apr 15 2019, 07:49 PM
Mike Bellis   Why not mount the power supply remote in an IP65/6...   Apr 15 2019, 07:22 PM
Spoke   Why not mount the power supply remote in an IP65/...   Apr 15 2019, 07:53 PM
Spoke   OK, the PCBs have been sent to the fab house. Shou...   Apr 16 2019, 09:12 PM
FlacaProductions   I deal with color temp every day. 3200 is tungsten...   Apr 16 2019, 11:08 PM
windforfun   I deal with color temp every day. 3200 is tungste...   Apr 23 2019, 04:02 PM
orthobiz   Why do these need a converter when your other tail...   Apr 17 2019, 12:26 PM
Spoke   Why do these need a converter when your other tai...   Apr 17 2019, 06:44 PM
Morrie   Ideally you would have a converter with no resisto...   Apr 17 2019, 07:58 PM
Spoke   Ideally you would have a converter with no resist...   Apr 19 2019, 02:34 PM
orthobiz   [quote name='orthobiz' post='2706213...   Apr 17 2019, 08:06 PM
914forme   PDBs going to be green or black in the final versi...   Apr 17 2019, 08:22 PM
Spoke   PDBs going to be green or black in the final vers...   Apr 18 2019, 08:02 PM
ClayPerrine   [quote name='914forme' post='2706330' date='Apr 1...   Apr 19 2019, 02:40 PM
Mblizzard   I will be in for a set of squares. Last lights on...   Apr 18 2019, 12:18 PM
eric9144   This is pretty awesome and totally something I...   Apr 18 2019, 01:57 PM
76-914   :popcorn:   Apr 19 2019, 07:16 AM
ValcoOscar   Same here... :popcorn: :popcorn: :popcorn: I s...   Apr 19 2019, 07:33 AM
DRPHIL914   thanks for taking this on! I asked about this ...   Apr 19 2019, 07:38 AM
Spoke   I agree about the comments on color, you don...   Apr 19 2019, 02:39 PM
Spoke   To reduce component and assembly cost, I'm loo...   Apr 22 2019, 06:59 PM
Al Meredith   would it make sense to have two levels, one for ru...   Apr 23 2019, 03:39 PM
Spoke   would it make sense to have two levels, one for r...   Apr 24 2019, 06:50 AM
Chi-town   Just a thought but if you're using a LED chip ...   Apr 24 2019, 09:25 AM
Spoke   Just a thought but if you're using a LED chip...   Apr 24 2019, 11:11 AM
Spoke   Have the PCBs in hand. Will assemble the first boa...   Apr 26 2019, 08:01 AM
Spoke   Here's the PCB under the glass. It will be int...   Apr 26 2019, 08:03 AM
DRPHIL914   :popcorn: Looking good! Cant wait to see the...   Apr 26 2019, 08:06 AM
Spoke   Things like this happen when you set the temperatu...   Apr 29 2019, 01:55 PM
mepstein   Things like this happen when you set the temperat...   Apr 29 2019, 02:14 PM
Spoke   With the correct settings, the oven worked fine. ...   Apr 29 2019, 03:06 PM
Spoke   All lit up with LED lenses. Won't be able to c...   Apr 29 2019, 03:10 PM
Spoke   Printed a jig to drill the heat sink for tapping. ...   Apr 29 2019, 03:13 PM
Spoke   Here's the light pattern with 0.5A per LED on ...   Apr 29 2019, 03:43 PM
Spoke   The glass lens fits nicely with the printed spacer...   Apr 29 2019, 03:46 PM
Spoke   Here's the light pattern with 0.5A with the gl...   Apr 29 2019, 03:48 PM
Spoke   Redesigned the spacer rings so the boards can scre...   Apr 29 2019, 04:49 PM
Spoke   These are the wrong screws. These are #4 x 5/16 wh...   Apr 29 2019, 04:51 PM
Spoke   The first fully built up PCB. Somehow I managed to...   Apr 30 2019, 04:10 AM
Spoke   Started doing some burn in on the first unit. Will...   Apr 30 2019, 04:15 AM
jkb944t   Started doing some burn in on the first unit. Wil...   Apr 30 2019, 06:15 AM
DRPHIL914   Looks great!!! Cant wait to get a set...   Apr 30 2019, 05:54 AM
Spoke   Burned in the prototype for about 20 hours this we...   May 3 2019, 07:59 PM
Spoke   The metal clips will need to be made for each unit...   May 3 2019, 08:01 PM
Spoke   The PCB fits nicely in the case. Will run this for...   May 3 2019, 08:04 PM
Spoke   Not sure how to connect up to the existing wires y...   May 3 2019, 08:07 PM
ClayPerrine   http://www.914world.com/bbs2/uploads_offsite/i.kym...   May 3 2019, 08:50 PM
Chi-town   Can you take a pic of the light output on a wall f...   May 3 2019, 09:58 PM
Spoke   This is the light pattern projected on the ceiling...   May 4 2019, 05:42 AM
Spoke   Got the prototype lit up in the foglight enclosure...   May 5 2019, 02:13 PM
Spoke   Compared the output of the LED foglight to the fog...   May 6 2019, 09:52 PM
Spoke   The driver side foglight is covered up and the LED...   May 6 2019, 09:57 PM
Chi-town   That upper washout will be blinding to oncoming tr...   May 6 2019, 10:48 PM
Luke M   Would the fog light lens make a difference ? I do ...   May 7 2019, 07:43 AM
Spoke   Would the fog light lens make a difference ? I do...   May 7 2019, 05:21 PM
mepstein   Would the fog light lens make a difference ? I d...   May 7 2019, 05:28 PM
Spoke   [quote name='Luke M' post='2711759' date='May 7 ...   May 7 2019, 05:35 PM
mepstein   [quote name='mepstein' post='2711910' date='May 7...   May 7 2019, 06:01 PM
Spoke   I have two early sets I can send you. One questi...   May 7 2019, 06:21 PM
mepstein   I have two early sets I can send you. One quest...   May 7 2019, 06:45 PM
JeffBowlsby   Open the housing and disconnect the wires! No...   May 7 2019, 06:55 PM
worn   Open the housing and disconnect the wires! N...   May 7 2019, 07:54 PM
Spoke   Open the housing and disconnect the wires! N...   May 8 2019, 08:02 PM
Spoke   I'm working on a 911 variant of the foglight l...   May 9 2019, 07:12 PM
mepstein   Early ones are on their way. They are in much bett...   May 9 2019, 07:23 PM
Chi-town   Sorry no fogs on my 75'   May 9 2019, 08:48 PM
Chi-town   Are you going to try different optics or main lens...   May 10 2019, 08:32 AM
mepstein   Are you going to try different optics or main len...   May 10 2019, 08:42 AM
Luke M   [quote name='Chi-town' post='2712683' date='...   May 10 2019, 10:31 AM
Spoke   Are you going to try different optics or main len...   May 10 2019, 02:54 PM
Chi-town   There's a big difference between an old 35 wat...   May 10 2019, 12:09 PM
Spoke   Put the board into one of the fixtures provided by...   Jun 1 2019, 06:52 AM
mepstein   Put the board into one of the fixtures provided b...   Jun 1 2019, 07:02 AM
Spoke   The early lenses are at least 5mm deeper than the ...   Jun 1 2019, 06:53 AM
Spoke   Does anyone make the rubber gasket that goes aroun...   Jun 1 2019, 07:04 AM
Chi-town   914 Rubber makes them   Jun 1 2019, 08:13 AM
Spoke   914 Rubber makes them Thanks. I ordered 2 sets....   Jun 1 2019, 09:13 AM
Mikey914   Ill make sure they get cross listed. We also ma in...   Jun 1 2019, 09:54 PM
Spoke   Finally got the 2nd 914 foglight assembled. This d...   Jun 11 2019, 07:44 PM
Spoke   Here's the 911 foglight fitted in the lens. Th...   Jun 11 2019, 07:47 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 18th July 2025 - 06:51 PM
