LED Foglight Project |
Spoke |
Apr 13 2019, 08:45 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. This is the spectral dispersion for the lens. |
StratPlayer |
Apr 13 2019, 01:34 PM
StratPlayer Group: Members Posts: 3,263 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Will you be making these for the rectangle style fog lights?
Spoke |
May 9 2019, 07:24 PM
Will you be making these for the rectangle style fog lights? If you can forward a single square fixture, I'll design a board for it. @StratPlayer If you don't have an extra fixture, maybe @mepstein has an extra square foglight fixture. |
DRPHIL914 |
May 10 2019, 08:13 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Will you be making these for the rectangle style fog lights? If you can forward a single square fixture, I'll design a board for it. @StratPlayer If you don't have an extra fixture, maybe @mepstein has an extra square foglight fixture. I have a rectangular fixture that is missing the glass lens I can send you . PM me with an address and I can sent it out tomorrow- i backdated my bumpers so I will be getting the early round LED that you are working on now, but my 75 wiring harness has the female connector for a spade from the light for + , the ground was supplied not by wire but thru the light body which grounded to the frame thru the mounting to bumper and bumper to car chassis . Anyway let me know if you want this light to use for your mock up Phil |
Lo-Fi Version | Time is now: 19th April 2024 - 04:13 AM |
