Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,194 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,338 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
Will you be making these for the rectangle style fog lights?
Spoke |
Will you be making these for the rectangle style fog lights? Once the round board is proved out, yes I plan to migrate to the rectangle style. Also want to do a rectangle style for the 911. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 18th July 2025 - 06:37 PM |
