Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,964 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I deal with color temp every day. 3200 is tungsten and 5600 is daylight - generally speaking. 4300 splits the difference with 3200 looking a little warm and 5600 looking a bit blue by comparison. I was thinking that 4000 or 5000 might be nice. 6500 would be really blue.
Lo-Fi Version | Time is now: 3rd July 2025 - 07:54 PM |
