Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,828 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
thanks for taking this on! I asked about this a year ago when I backdated my bumpers and sourced a nice set of OEM NOS early round fogs. I had put the H1 LED bulbs in my late square fogs and they worked fine but this is a much better way to go. I don't want to clog this documentation thread with requests so I will be looking forward to a new thread for purchase of these once you are ready !
I agree about the comments on color, you don't want to go too blue so probably staying closer to the 4000-5000k max would be best - why not a "spectrum" not just one but rather 2or 3 different ones all on the same board , how would that work? Phil |
Spoke |
I agree about the comments on color, you don't want to go too blue so probably staying closer to the 4000-5000k max would be best - why not a "spectrum" not just one but rather 2or 3 different ones all on the same board , how would that work? Phil Not sure what a light would look like with mixed temperature LEDs. I just ordered 5000K LEDs enough to do 4 boards. We'll see what they look like when put together. Also ordered the heatsinks and all other components. Digikey was out of the Carclo 10192 lenses so I'll order them through Arrow. |
Lo-Fi Version | Time is now: 1st July 2025 - 09:52 PM |
