Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
Chi-town |
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California ![]() |
Just a thought but if you're using a LED chip with an optic and then putting behind a standard thick fluted lens the output is going to be severely reduced. I would guess roughly 30%.
Have you put the standard lens on top of your prototype to see what happens? |
Lo-Fi Version | Time is now: 30th June 2025 - 07:15 PM |
