Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
Spoke |
Things like this happen when you set the temperature profile wrong on the infrared oven.
@mepstein I have your foglight board. Not sure why it doesn't light up but I'm working on that. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Things like this happen when you set the temperature profile wrong on the infrared oven. @mepstein I have your foglight board. Not sure why it doesn't light up but I'm working on that. (IMG:style_emoticons/default/beerchug.gif) That looks more like when I try to do electrical work. |
Lo-Fi Version | Time is now: 5th July 2025 - 01:55 PM |
