Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 ![]() |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. ![]() This is the spectral dispersion for the lens. ![]() |
Chi-town |
Senior Member ![]() ![]() ![]() Group: Members Posts: 843 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California ![]() |
There's a big difference between an old 35 watt halogen bulb behind secondary reflector and multiple LED output straight out the lens.
If you look at the output shot he posted the light is everywhere there's not even a focused beam to aim. LEDs are meant to be in a projector housing with a defined cutoff to be legal and safe for oncoming traffic. I spent a year dealing with LED lights and SAE/DOT regulations and there are some pretty specific limitations to keep you from blinding others. With out improved optics and light control these are just a bad idea |
Lo-Fi Version | Time is now: 19th January 2021 - 12:52 PM |
