Bilstein HD rear lower spring perch height help, Recommendations for lower spring perch setting on bilsteins |
Krohn |
Apr 13 2019, 01:05 PM
Newbie Group: Members Posts: 9 Joined: 6-November 14 From: Santa Barbara, CA Member No.: 18,091 Region Association: Southern California |
I'm finally at the fix the severely sagging rear springs project for my car, and am wondering if there's any guidance on where to set the lower spring perch for the new rear Bilstein shocks?
I'm keeping the car as sock as possible, think of me as a James May if you must, so I have a new set of stock ride height springs (85 lb) and the new replacement struts. Comparing the old and the new side by side, it almost seems that I need to move t he circlip all the way to the top on the new shocks... but that seems almost crazy! Since I'm aware that the new springs, at 85 lbs, are heavier than the originals (maybe 70?), would it be better to move the perch down one relative to the old shocks? Old springs/shock on the left, new on the right (IMG:http://www.914world.com/bbs2/uploads_offsite/1.bp.blogspot.com-18091-1555182313.1.jpg) Any advice or recommendations out there? The stock rear sway bars stay (front and rear), which was also a driving motivation for keeping a lighter weight spring in the back. Maybe it's time for a project thread... but progress is piecemeal and slow, so it might drag on, and on, and on... Thanks! Robert |
914Sixer |
Apr 13 2019, 01:24 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Start at 2 up from bottom The spring carries the weight not the shock.
Lo-Fi Version | Time is now: 19th May 2024 - 06:45 PM |
