Tail Light Lens Alignment/Fit, Am I missing a seal? |
FlacaProductions |
May 31 2019, 09:56 AM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I'll try that with the new ones - already tried that with the old ones with no joy. The reverse section of the lens seems to be too far inboard of the white nut to have much influence. These may have been over-tightened by the PO - if you look closely at the picture, the white section sticks out and then snugs up near where the post/white nut are but then starts to head back out when you get beyond that.
burton73 |
May 31 2019, 10:08 AM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
As I am in the plastic Biz and we have a over for curing plastic I would try to put it in the oven at say 250 degrees or so and let it get a little flexible and then bend it right for the fit. You may be able to put it on the body of the light and have it bend the way you need it to go. After cooling it should stay that way.
I would try this on an old lens at first to see. Bob B |
FlacaProductions |
May 31 2019, 08:26 PM
good call. As soon as I get the opportunity - we'll see how well the new ones fit and if they're good, i'll heat up the old ones and see what happens...it won't be until July though...
Lo-Fi Version | Time is now: 5th May 2024 - 07:36 AM |
