Deve’s or Goetze rings for 2.0L, Which rings are better for 2.0L |
lonewolfe |
Apr 13 2019, 08:50 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I have a nice set of Euro Kolbenschmidt flat top 94.0mm 2.0L pistons & cylinders and want to know if Deves or Goetze are the preferred rings for these pistons. Both are available. What’s been your experience?
Mark Henry |
Apr 14 2019, 06:42 AM
Both are good choices, Deves seat way faster, Goetze are hard as hell and can take 1000+ miles to fully seat. With the goetze don't worry about the oil consumption till you have around 2k miles on the engine.
Any ring brand make sure you use a dino oil for brake in. |
lonewolfe |
Apr 14 2019, 10:51 PM
Both are good choices, Deves seat way faster, Goetze are hard as hell and can take 1000+ miles to fully seat. With the goetze don't worry about the oil consumption till you have around 2k miles on the engine. Any ring brand make sure you use a dino oil for brake in. Thanks Mark! I do know about using Brad Penn oil for the break-in. That’s the kind of information I need about the rings too! Sounds like Deves is the way to go. |
Mark Henry |
Apr 15 2019, 07:42 AM
Measure your ring groves or old rings before you order, IIRC there's a couple different thicknesses of rings.
Mark Henry |
Apr 15 2019, 07:47 AM
Lo-Fi Version | Time is now: 19th April 2024 - 06:15 AM |
