Calling all A/C Experts, Anyone experienced this? |
jdamiano |
Apr 14 2019, 04:20 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
So I swapped my York for a Sanden and hooked the old lines up and charged it with R-134 about a month ago. I purchased the car with non-functionality AC. Didn’t touch anything else in the system. Went for a couple hundred mile cruise down A1A along the beach today with the wife. 80+ temp all day. The A/C on max all day and all it did was cut the edge off the heat. Then about 30 minutes before I was home we drove through a driving rain. It lasted about 5 minutes. A/C started blowing ice cold!!! I talking ear stinging cold. We had to turn it down. Stayed blowing ice cold all the way home. Any ideas?
914_teener |
Apr 15 2019, 10:51 AM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
https://www.hagerty.com/articles-videos/art...nts-and-the-law
From the Haggerty's site. I've done this one. Evac everything and flush it completely. Change the orifice tube for R13. Get a new drier to make sure there is NO moisture or dirt in the system. I went through a can of flush agent and blew it through everything with really dry air. Get or rent a gauge set if you don't have one already. Hook up the set and pull vacuum enough to boil of ANY residual moisture and to check for leaks. Charge the systems and check your gauge set for the recommend temp split to amount of refrigerant at the correct pressure. Should be good to go after that, but check it on a good hot day. You didn't state how the evap coil or condensing coil is set up but that could also be an issue as well. If you didn't completely flush the system you will stunt the lifespan of your compressor. Good luck. Edit.....I feel old sometimes....I should have said orifice tube not expansion valve. If you clean and flush your system well the exp valve sb ok. |
Lo-Fi Version | Time is now: 28th March 2024 - 05:30 AM |
