Oil leak frustration. Expert advise needed |
3stewarts |
Apr 14 2019, 05:03 PM
Newbie Group: Members Posts: 27 Joined: 30-March 12 From: Kansas City MO Member No.: 14,322 Region Association: None |
I have an oil leak positively identified with the use of leak tracer dye and UV light dead center on top of the oil pump. I have installed a new 36 mm type one oil pump modified for the type 4. I also applied a generous amount of my favorite gasket sealer yet the leak remains. It will only leak with the engine running which indicates to me it is under pressure. My theory is that the case halves may not have had enough sealer on them during engine asssembly.
My question then is how do I seal this thing without splitting the case? Can I apply sealant to the circumference of the oil pump? Any thoughts or experiences appreciated. |
3stewarts |
May 1 2019, 05:35 PM
Happy to report the sealer did the trick!
I applied a thin layer along the case seam on top plus the thin layer upon the “gasket surface”. So far so good! Thanks again to all who offered advice. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:58 PM |
