Oil leak frustration. Expert advise needed |
3stewarts |
Apr 14 2019, 05:03 PM
Newbie Group: Members Posts: 27 Joined: 30-March 12 From: Kansas City MO Member No.: 14,322 Region Association: None |
I have an oil leak positively identified with the use of leak tracer dye and UV light dead center on top of the oil pump. I have installed a new 36 mm type one oil pump modified for the type 4. I also applied a generous amount of my favorite gasket sealer yet the leak remains. It will only leak with the engine running which indicates to me it is under pressure. My theory is that the case halves may not have had enough sealer on them during engine asssembly.
My question then is how do I seal this thing without splitting the case? Can I apply sealant to the circumference of the oil pump? Any thoughts or experiences appreciated. |
Bleyseng |
Apr 14 2019, 05:24 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
A 36mm oil pump, sheesh that's pretty big. Too much pressure?
3stewarts |
Apr 14 2019, 05:29 PM
Mark Henry |
Apr 14 2019, 06:24 PM
A 36mm oil pump, sheesh that's pretty big. Too much pressure? Maybe? Purchased from the type 4 store. Only option. Really? (IMG:style_emoticons/default/blink.gif) That must be leaking around the pump pretty good! Why it's the wrong pump to use. I use the shadek pumps, 26mm on my big T4, 30mm needs a pressure relief cover. Shadeks quality is good except for the case hole size, I now run a thin bead of yamabond inside the case hole past the galley holes. Real thin bead because most of it will be squeezed into the case, a small amount of yamabond will stay put. Yamabond, hondabond, threebond basically the same,the gray stuff all made by Threebond, IIRC Threebond 1104 NEO You could try cleaning it up good, including inside the hole as best you can, and a thin bead of yamabond inside and out of the case in this area. Only put the yamabond where you're 100% positive it's 100% clean and degreased. If that doesn't work nothing short of splitting the case will work. If you split the case I'd inspect that area. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:57 PM |
