An original paint survivor or a perfect repainted car? |
mb911 |
Apr 15 2019, 02:13 PM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I would just reclear it.. It's completely doable.. It's a wet sand and clear process.. Best of both worlds.
Jamie |
Apr 15 2019, 06:32 PM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I would just reclear it.. It's completely doable.. It's a wet sand and clear process.. Best of both worlds. I know my original owner Dad never waxed the L99A Delphi Green metallic on my 73, and after the clearcoat began peeling I had the exterior stripped to metal and resprayed about 4 yrs. ago. My paint/body guy was an artist, used original paint from D-land, and the match is perfect with other original painted areas. I cringe when I see what y'all are paying out there on the left coast, I was well pleased with my $3000 outcome. He did remove all body parts that could be taken off, lights, trunks, doors,etc. and rubber in many cases. I did the valances and long covers, and I hate to see body rubber parts with overspray. So I vote for maintaining the parts that can be original paint, and good matching repaint of the damaged paint that shows. Now my future problem for any body work/paint needed on my cars is questionable since he has retired.(IMG:style_emoticons/default/aktion035.gif) |
jagalyn |
Apr 15 2019, 07:02 PM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
I tried a wax on the the paint as suggested above... but was surprised when I waxed the clear coat.
thelogo |
Apr 16 2019, 04:57 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
jagalyn |
Apr 16 2019, 07:55 AM
Preservation before restoration. I agree. Preservation before restoration. Beauty is in the eye of the beholder. I think she's beautiful. (IMG:style_emoticons/default/smile.gif) |
Unobtanium-inc |
Apr 16 2019, 08:40 AM
Advanced Member Group: Members Posts: 2,199 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Do some research, ask a pro and see if you can clear coat it, Wash then use wax and grease remover, mask, light scrubbing with 800g scotch bright pad and clear it. You might still see it a bit, but it should blend in. I would go with this idea, if you can save the original paint do that. I've seen guys do things like wet sand a complete car to save the paint. |
Chris914n6 |
Apr 16 2019, 08:57 AM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
^^ They call it "paint correction"
Clay rub, compound, polish, wax. In most cases it looks better than factory. I'm about to do it to an 05 Beetle that spent it's life in the sun. If I have time before WRC I'll do my 914 with an 80s respray. |
jfort |
Apr 16 2019, 09:01 AM
Senior Member Group: Members Posts: 1,134 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
At Mosport Vintage Grand Prix last spring there was a guy in the tarmac next to us with an old silver 911 with paint that looked like yours. It was very cool to see that car being used.
Steve |
Apr 16 2019, 10:00 AM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It's whatever makes you happy, but cost does come into play and priority. My silver 914 had an 1/8" thick of crappy repaints. The previous owner also installed steel flairs and had the body shop just paint the flairs. The car was diamond silver metalic and the flairs were Carrera GT silver. My kids called the car "50 shades of Gray". I just spent $15k taking the car to bare metal and repainting the car Alaska Blue Metalic.
Bottom line... Whatever makes you happy!! It's your car. |
JOEPROPER |
Apr 16 2019, 11:14 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Prep it for another coat of clear.
Mikey914 |
Apr 16 2019, 02:11 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You can wet sand and polish to be reshot with clear. Best of both worlds. Not really hard but I’d have it reshot in a professional booth. As there’s not base work other than a careful wet sanding it might not be too bad to have it done professionally.
Worth checking it out (IMG:style_emoticons/default/biggrin.gif) |
raynekat |
Apr 17 2019, 05:34 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I'll take the new paint everyday. They've made a little bit of progress in paint technology over the past 50 years, so the newer paints are hands down better and last longer, look better.
twistedstang |
Apr 19 2019, 08:47 AM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
Original all day long. Pretty new paint can hide ugly new bodywork
brownaar |
Apr 19 2019, 01:59 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Seems to me since this was a known problem that Porsche issued a service bulletin for, fixing the clear coat would be acceptable.
Aaron |
Amphicar770 |
Apr 20 2019, 06:23 AM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Original paint unless it is totally trashed. For any repaint, I would want to see lots of pics of the bodywork underneath before it hit the spray booth. "Sell me red paint" can hide a lot of sins.
orthobiz |
Apr 21 2019, 12:52 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
orthobiz |
Apr 21 2019, 12:54 PM
I have two survivors. One is light ivory and the other is phoenix red. I’m just glad they are not metallic!
Paul |
horizontally-opposed |
Apr 21 2019, 03:20 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
To each their own.
Prefer original paint, but there is a perverse/reverse logic to original paint when it comes to use: It's actually riskier to use a car in original paint than one that's been restored. It's only original once...where it can be restored multiple times. Like I said, I prefer original paint...but super original cars have their downsides when it comes to risk factors. Then again, life is too short either way. "Drive the cars" remains the best strategy… |
Fatarse |
Apr 26 2019, 01:36 PM
Newbie Group: Members Posts: 12 Joined: 25-June 16 From: Scottsdale, AZ Member No.: 20,143 Region Association: None |
Great thread. How does preservation vs restoration of paint affect the value of these cars? I also have what looks to be a 73 2.0 survivor, but paint is in significantly rougher shape. No rust, but visible dings throughout the paint and horrible touch up to the Alaska Blue.
Steve - who did you go with for your Alaska Blue Metallic repaint? |
Larmo63 |
Apr 26 2019, 05:57 PM
People in SoCal who know me and my black /6 conversion probably wonder why I don't do more to make the car's exterior better.
I like the fact that it shows it's scars and I don't really care about road rash. I may do something someday, but for now, it's a driver. I keep the windows on it spotless. |
Lo-Fi Version | Time is now: 25th April 2024 - 01:31 PM |
