Plenum Repair, Solder? Braze? Weld? Epoxy? Magic? |
ctc911ctc |
Apr 15 2019, 02:35 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I have been chasing a vacuum problem. Found 2 likely culprits so I started a new thread.
1. BOTH plenum support columns at the top are leaky. I just tried soldering and then brazing, both did not work. I am reluctant to weld because of the gage of the material and the skill of the welder......grin 2. The control shaft in the Throttle Body is leaking as well, is there any way to fix this without milling and new sleeves inserted? Also, as luck would have it, my son cleaned and painted the unit PRIOR to me having time to test it........ Thank you, CTC911CTC |
76-914 |
Apr 15 2019, 02:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Brazing is fine but might be easier to buy a known good one. The shaft needs to be redrilled with new bushings. The bushings are self lubricating and will be installed "in line" when done correctly. If that shaft were to bind when wide open you might be in for "the ride of your life".
I prefer the silicone rubber for those runners but you usually need to buy a 3' length at a diesel shop and it ain't cheap. It does take heat well and will out last the OEM sleeve. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:37 AM |
