Plenum Repair, Solder? Braze? Weld? Epoxy? Magic? |
ctc911ctc |
Apr 15 2019, 02:35 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I have been chasing a vacuum problem. Found 2 likely culprits so I started a new thread.
1. BOTH plenum support columns at the top are leaky. I just tried soldering and then brazing, both did not work. I am reluctant to weld because of the gage of the material and the skill of the welder......grin 2. The control shaft in the Throttle Body is leaking as well, is there any way to fix this without milling and new sleeves inserted? Also, as luck would have it, my son cleaned and painted the unit PRIOR to me having time to test it........ Thank you, CTC911CTC |
worn |
Apr 15 2019, 05:30 PM
can't remember Group: Members Posts: 3,152 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Also, as luck would have it, my son cleaned and painted the unit PRIOR to me having time to test it........ Luck has nothing to do with that sort of thing. I have had excellent results with silver containing filler rod when brazing reluctant steel. It comes with bright orange flux coat and is kinda spendy. Good luck. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:24 AM |
