Plenum Repair, Solder? Braze? Weld? Epoxy? Magic? |
ctc911ctc |
Apr 15 2019, 02:35 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I have been chasing a vacuum problem. Found 2 likely culprits so I started a new thread.
1. BOTH plenum support columns at the top are leaky. I just tried soldering and then brazing, both did not work. I am reluctant to weld because of the gage of the material and the skill of the welder......grin 2. The control shaft in the Throttle Body is leaking as well, is there any way to fix this without milling and new sleeves inserted? Also, as luck would have it, my son cleaned and painted the unit PRIOR to me having time to test it........ Thank you, CTC911CTC |
mgphoto |
Apr 16 2019, 03:33 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I would find another, dangerous to weld or braze on the plenum because of residual fuel, just like a fuel tank.
Marine Tex is great stuff, used it to seal a vw gas tank. But it is not a permanent, vibration can loosen the material. |
Lo-Fi Version | Time is now: 6th May 2024 - 05:55 PM |
