| rgolia |
Apr 15 2019, 02:41 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
Not sure what happened over the winter, but my oil pressure gauge is now pegged to the right. Worked fine all last driving season. Can a shot sender unit be the cause? Mine is really old. (IMG:style_emoticons/default/sad.gif)
| Tom_T |
Apr 15 2019, 02:45 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Try changing to clean oil & cleaning the sender good first, & check the wiring & connectors up to the console gauge. May just be gunked-up.
(IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| SirAndy |
Apr 15 2019, 02:47 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,425 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Did you fiddle with the wires? Sounds like you switched the sending unit wire and ground wire on the gauge.
G stands for "Geber" which means sending unit in German, it's *not* ground ... (IMG:style_emoticons/default/shades.gif) |
| 914Toy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
Not sure what happened over the winter, but my oil pressure gauge is now pegged to the right. Worked fine all last driving season. Can a shot sender unit be the cause? Mine is really old. (IMG:style_emoticons/default/sad.gif) My guess, wiring - check connections and then possible grounding. |
| Dave_Darling |
Apr 15 2019, 03:55 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,323 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Something electrical--
You unplugged the wire (though I think that would cause a zero reading rather than high) You smashed the wire somewhere, shorting it to ground The case of the sender is no longer grounded correctly You hooked it up wrong --DD |
| 914Sixer |
Apr 15 2019, 04:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,412 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the metal brackets that hold it. Now you have the sender grounded out.
| bdstone914 |
Apr 15 2019, 05:36 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,253 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the mental brackets that hold it. Now you have the sender grounded out. (IMG:style_emoticons/default/agree.gif) |
| bdstone914 |
Apr 15 2019, 05:39 PM
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the mental brackets that hold it. Now you have the sender grounded out. (IMG:style_emoticons/default/agree.gif) Either that or in the sender. Remove the se der wire from the sender. Connect an Ohm meter to the sender terminal G and to ground. If it shows continuity to ground the sender is bad. It should show a low resistance level and change with oil pressure change. |
| rgolia |
Apr 16 2019, 10:00 AM
Thanks for all the advice. I am going to snoop around and see if anything got messed up. I think I will start by taking the gauge out and wiring it direct to the sender. If it works, that should take a sender issue off the table.
| Chi-town |
Apr 16 2019, 10:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Remove the wire from the sender if the gauge drops it's the sender, if it doesn't the wire is shorted to ground somewhere.
Lo-Fi Version | Time is now: 11th February 2026 - 10:32 AM |
