| rgolia |
Apr 15 2019, 02:41 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
Not sure what happened over the winter, but my oil pressure gauge is now pegged to the right. Worked fine all last driving season. Can a shot sender unit be the cause? Mine is really old. (IMG:style_emoticons/default/sad.gif)
| 914Sixer |
Apr 15 2019, 04:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,412 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the metal brackets that hold it. Now you have the sender grounded out.
| bdstone914 |
Apr 15 2019, 05:36 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,253 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the mental brackets that hold it. Now you have the sender grounded out. (IMG:style_emoticons/default/agree.gif) |
| bdstone914 |
Apr 15 2019, 05:39 PM
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the mental brackets that hold it. Now you have the sender grounded out. (IMG:style_emoticons/default/agree.gif) Either that or in the sender. Remove the se der wire from the sender. Connect an Ohm meter to the sender terminal G and to ground. If it shows continuity to ground the sender is bad. It should show a low resistance level and change with oil pressure change. |
rgolia Oil Pressure Gauge Apr 15 2019, 02:41 PM
Tom_T Try changing to clean oil & cleaning the sende... Apr 15 2019, 02:45 PM
SirAndy Did you fiddle with the wires? Sounds like you swi... Apr 15 2019, 02:47 PM
914Toy
Not sure what happened over the winter, but my oi... Apr 15 2019, 02:47 PM
Dave_Darling Something electrical--
You unplugged the wire (tho... Apr 15 2019, 03:55 PM
rgolia Thanks for all the advice. I am going to snoop ar... Apr 16 2019, 10:00 AM
Chi-town Remove the wire from the sender if the gauge drops... Apr 16 2019, 10:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 11th February 2026 - 09:02 AM |
