Throw out bearing failure, What are the symptoms? |
malcolm2 |
Apr 15 2019, 06:12 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
malcolm2 |
Apr 18 2019, 04:42 PM
Washer under the ball pivot question.
So the washer raises the pivot point, correct? Remind me why we add the washer. Does it add pressure? Or distance the TOB can travel? |
porschetub |
Apr 18 2019, 05:05 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Washer inder the ball pivot question. So the washer raises the pivot point, correct? Remind me why we add the washer. Does it add pressure? Or distance the TOB can travel? No you shouldn't need the washer but do replace the nylon ball cup anyway,is that a Sach's pressure plate or aftermarket...don't see the usual markings to indicate it is ?. IMO I wouldn't use that pressure plate again as the spring fingers appear to be pretty chewed out ,most likely caused by the bearing seizing up and collapsing . If you do replace the pressure plate only buy a Saches ZF no aftermarket ones cut the the mustard again IMO. Good luck. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:32 AM |
