Throw out bearing failure, What are the symptoms? |
malcolm2 |
Apr 15 2019, 06:12 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
dlee6204 |
Apr 18 2019, 04:45 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Washer inder the ball pivot question. So the washer raises the pivot point, correct? Remind me why we add the washer. Does it add pressure? Or distance the TOB can travel? To compensate if you'd had your flywheel machined down. If your flywheel hasn't been surfaced, you shouldn't need it |
malcolm2 |
Apr 18 2019, 06:02 PM
Washer inder the ball pivot question. So the washer raises the pivot point, correct? Remind me why we add the washer. Does it add pressure? Or distance the TOB can travel? To compensate if you'd had your flywheel machined down. If your flywheel hasn't been surfaced, you shouldn't need it Plan is to buy a new PP and clutch. Clutch looks ok, but what the hell. The flywheel was machined in 2012. I figured i would take it back to Tennessee Clutch. What are the tolerances, how to measure? I wonder if TN Clutch would know or even measure. I always got there at 4 and they were all drinking Busch. |
Lo-Fi Version | Time is now: 5th May 2024 - 07:01 AM |
