Car running like crap, 4 days before Hershey |
saigon71 |
Apr 16 2019, 07:29 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Could use some "check this" help:
Running a 2056 D-jet. Over the winter I adjusted the valves and changed the oil. It didn't need much else. This Spring, I installed a new distributor cap and new set of points. Adjusted dwell to 50 degrees before setting timing dead on at 27 degrees BTDC. The car was running awesome. (IMG:style_emoticons/default/driving.gif) All of the sudden, the car has developed a pretty serious intermittent miss. There have been times it runs flawless on a test drive, only to start sputtering the next drive. When the sputtering and bucking occurs, there is sometimes an audible "pop" or "knock" sound coming from the engine bay. I've got a new FI wiring harness from Jeff Bowlsby installed. So far I have done the following: -Check fuel lines for kinks -Added "Star-Tron" enzyme fuel treatment to fuel stored in tank for winter, have since added two tanks of fresh gas -Fuel steady pressure at 31PSI (but I couldn't get the car to act up when I had the gauge attached) -Verified point gap hadn't changed after setting dwell -Verify that CHT is tight (CHT is almost new) -Cleaned & adjusted trigger points -Unplugged TPS - it did not make a difference -Checked FI harness grounds at the back of the engine -Pulled all 4 spark plugs to check for fouling - they all looked good -Swapped the coil with a known good one Any advice on other things to check would be appreciated. |
dralf |
May 15 2019, 07:41 AM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
I have finally started working on a similar running issue with my 1975 that still has D jet injection. My engine would actually die while driving, I could restart it, and if the REVs were above 4000 RPM it would continue to run and die if the RPMs dropped. I does not do this all the time but is a scary situation on the interstate. My previous posts regarding this issue have suggested I replace the coil, some of the wiring harness, check grounding and points. Reading this post makes me wonder if I do not have an alternator / power to the coil issue. I am going to use some of the suggestions and checks from this post to look at my car for source of my problem.
Lo-Fi Version | Time is now: 18th May 2024 - 04:24 PM |
