Car running like crap, 4 days before Hershey |
saigon71 |
Apr 16 2019, 07:29 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Could use some "check this" help:
Running a 2056 D-jet. Over the winter I adjusted the valves and changed the oil. It didn't need much else. This Spring, I installed a new distributor cap and new set of points. Adjusted dwell to 50 degrees before setting timing dead on at 27 degrees BTDC. The car was running awesome. (IMG:style_emoticons/default/driving.gif) All of the sudden, the car has developed a pretty serious intermittent miss. There have been times it runs flawless on a test drive, only to start sputtering the next drive. When the sputtering and bucking occurs, there is sometimes an audible "pop" or "knock" sound coming from the engine bay. I've got a new FI wiring harness from Jeff Bowlsby installed. So far I have done the following: -Check fuel lines for kinks -Added "Star-Tron" enzyme fuel treatment to fuel stored in tank for winter, have since added two tanks of fresh gas -Fuel steady pressure at 31PSI (but I couldn't get the car to act up when I had the gauge attached) -Verified point gap hadn't changed after setting dwell -Verify that CHT is tight (CHT is almost new) -Cleaned & adjusted trigger points -Unplugged TPS - it did not make a difference -Checked FI harness grounds at the back of the engine -Pulled all 4 spark plugs to check for fouling - they all looked good -Swapped the coil with a known good one Any advice on other things to check would be appreciated. |
ejm |
May 5 2019, 12:05 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
You need to check the voltage at coil terminal #15 and maybe at pin 1 of the white 4 pin FI harness plug on the relay board. High resistance somewhere will reduce voltage to the consumers. I would plug another ignition switch into the harness and see if the problem goes away.
saigon71 |
May 5 2019, 12:57 PM
You need to check the voltage at coil terminal #15 and maybe at pin 1 of the white 4 pin FI harness plug on the relay board. High resistance somewhere will reduce voltage to the consumers. I would plug another ignition switch into the harness and see if the problem goes away. Thanks Ed. 13.7V on terminal 15 of the coil. Which pin is pin 1 on the white 4 pin FI harness? Heading out to swap out the ignition switch. |
Lo-Fi Version | Time is now: 5th May 2024 - 07:42 AM |
