Seat won’t stop sliding back and forth, Seat problems |
mtc911 |
Apr 16 2019, 07:29 PM
Member Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States |
When I use the handle to put the seat where I need it for comfortable driving position it will not stay in place. As soon as I accelerate or put any pressure on the seat back it slides all the way back. I have taken 914 seats out in the past - just curious what I’m getting into or if anyone has had this problem. Floor pans have been replaced by PO and new hinges are in place. Thanks.
Mike Bellis |
Apr 16 2019, 08:59 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
You have to pull the seat and find out why. Two 10mm bolts (6mm w/10mm head) at the rear of each slider. Remove bolts & wiggle seat and it will come out. Flip it over and find out what is binding the latch.
Carl La Fong |
Apr 16 2019, 09:12 PM
Member Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None |
Single engine Cessnas had the same problem but with more catastrophic results. (IMG:style_emoticons/default/laugh.gif)
Mikey914 |
Apr 17 2019, 02:30 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Perhaps the “spring” needs to be bent out a little more. Adding more pressure to the lock-in mechanism?
Easy to see once you have apart. |
rgalla9146 |
Apr 17 2019, 06:00 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Sounds like the lock pin on the slider release is worn or rounded off, same might
apply to the perforated track. Or....the leaf spring is not pressing the pin into the rack. OR ......... Too much Horsepower |
dr914@autoatlanta.com |
Apr 17 2019, 07:46 AM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
possibly the tension spring has broken not keeping the seat loop segments firmly placed in the rack slots, OR you have something installed backwards
When I use the handle to put the seat where I need it for comfortable driving position it will not stay in place. As soon as I accelerate or put any pressure on the seat back it slides all the way back. I have taken 914 seats out in the past - just curious what I’m getting into or if anyone has had this problem. Floor pans have been replaced by PO and new hinges are in place. Thanks. |
peteinjp |
Mar 27 2022, 11:47 PM
Member Group: Members Posts: 200 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
I’m having this exact same issue. Wonder if the OP found the fault?? Will pull the seat again- any further advice?
Rob-O |
Mar 28 2022, 07:57 AM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
If I remember correctly I think if the rails that are attached to the seat are on the wrong side this will happen. Or is it if it’s on the wrong seat (driver adjuster on passenger seat, passenger adjuster on drivers seat). I can’t remember but try the switching the rail from seat to seat.
emerygt350 |
Mar 28 2022, 08:26 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
peteinjp |
Mar 28 2022, 05:35 PM
Good call- I had a passenger yesterday and the same thing happened on the passenger seat as well when I nailed it. I’ll pull the seats and post what I find.
Is 230hp too much?? Haha. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:55 PM |
