My 5 lug Boxster swap |
twistedstang |
Apr 17 2019, 06:22 AM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
Figured I would share a few pics of my 5 lug swap on my 75. I used 3.5 spaced 911 struts and Boxster calipers all around using the Rebel Racing kit. Wheels are 16x6 and 16X7 fuchs with 195/55/16s on all 4. I originally had 911 wheels all the way around but the rears had a slight interference with the calipers. Rather than use spacers I switched to 951 rears and the fit is great. |
mmascari |
Apr 17 2019, 06:14 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Did you have to use spacers so the wheels didn't rub on the caliper? I have the same conversion and the 7" Euromeister wheel rubbed the caliper on the inside.
twistedstang |
Apr 18 2019, 05:10 AM
Did you have to use spacers so the wheels didn't rub on the caliper? I have the same conversion and the 7" Euromeister wheel rubbed the caliper on the inside. The rear setup with 911 Fuchs would have needed a 1/8" spacer. The caliper was touching the rim. I switched to a 951 fuch in back and it has plenty of clearance. Same size wheel, same offset, but the spokes are pushed forward a bit and the mounting hub on the wheel is deeper to make up for it. |
mmascari |
Apr 18 2019, 05:44 PM
Did you have to use spacers so the wheels didn't rub on the caliper? I have the same conversion and the 7" Euromeister wheel rubbed the caliper on the inside. The rear setup with 911 Fuchs would have needed a 1/8" spacer. The caliper was touching the rim. I switched to a 951 fuch in back and it has plenty of clearance. Same size wheel, same offset, but the spokes are pushed forward a bit and the mounting hub on the wheel is deeper to make up for it. Ah, that is the key....get 951 fuchs. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:53 PM |
