Something Evil Part II, Starting Over |
Mblizzard |
Apr 17 2019, 08:17 AM
Well I have been delayed with life and too many things going on. But after purchasing a lot of parts, it is time to start the process.
Up front big thanks to Charles and Nicole at the Type 4 Store for putting up with so many questions. Thanks to Len Hoffman for waiting on me for so long on the heads. Also to Jake Raby for his Type 4 build CD and while not giving build advice but pointing me in the right direction on a number of issues. I am afraid to look at all of the other vendor receipts as I might start to add it all up $$$$ but I will compile a list of all the vendors and add photos. So the basics. Going for a 2.6 L FI with Microsquirt. Looking to hit 9.5:1 compression. 102 mm Nickies with Custom 102mm Dished JE Pistons for 78mm stroke and 22mm pins. 78 mm crank - New this time! H-beam Rods 5.325 with Type 1 Rod Journals LE-200 heads - Valve sizes: 44mm x 38mm by Manley, intake ports flow 200CFM @ .500” valve lift, and ceramic coated. 911 swivel foot valve adjusters SPEC Clutch Kit - Stage 1 Lightened flywheel Type 4 Store Cam Part# 9500 with Parkerized Lifters and Modified Cam Gear, chromoly pushrods Intake Valve Lift: .500 Duration: 284 Duration@ .050": 250 Exhaust Valve Lift: .500 Duration: 300 Duration@ .050": 270 Mahle bearings throughout 315cc/min Fuel Injector: Bosch 0280150945 48 mm CB Performance intakes. Dual throttle bodies with CSP linkage Modified 30mm Oil Pump Racewear Case thru-Stud Kit and Head Stud Kit Tangerine Racing Remote Oil Cooler Kit Planning on Tangerine Racing 1 1/2" Street System: - High Temp coated header with EVO II Silencer Case and all the parts are going to shop Friday for opening up to fit the 102s and balancing of all parts. Goal is to be done by Okteenerfest! May have potential to be evil? Thoughts suggestions? |
thelogo |
Apr 17 2019, 08:27 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Not trying to drudge up old memories but im trying to learn from your experiences
Can you talk about what road you went this time vs your last type 4 . You dont have to tell me your goals with these motors I can tell its to haul ass and i appreciate you staying Loyal to the /4 cause im sure this one cost /6 comversion money . amd that /6 has been hard to resist |
Chi-town |
Apr 17 2019, 09:29 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
You forgot what you're controlling this with, stock FI?
Mblizzard |
Apr 17 2019, 09:57 AM
VaccaRabite |
Apr 17 2019, 10:10 AM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
What happened with your 2056?
Zach |
Mblizzard |
Apr 17 2019, 10:15 AM
Not trying to drudge up old memories but im trying to learn from your experiences Can you talk about what road you went this time vs your last type 4 . You dont have to tell me your goals with these motors I can tell its to haul ass and i appreciate you staying Loyal to the /4 cause im sure this one cost /6 comversion money . amd that /6 has been hard to resist I am a fan of the 4. I know I have spent more money on this than a 6 conversion but the 4 is what I love. Overall, I have always felt there was more in the 4 than most gave it credit for. The advance in technology regarding FI and engine components (Nickies and Lens heads) has made it possible to get that performance without building an engine that is a bomb waiting to explode. I broke a 78mm crank on my last engine. It was a 2.3 with 98mm brial cylinders and Mahle pistons with a great set of big valve heads which were ported. On a very poor tune this put 115hp to the wheels. It was really fun to drive and there was still more there. I still have the components if anyone wants to go big 4 for a lower cost. So this is just the next level. This will be my last one to build so I am going all out. I think the last build was a great compromise between spending the 6 money and building a reasonably high HP 4. The build is what compromised the crank. Hard to survive when a bearing is installed incorrectly! Bad things happen! So same basic road with higher quality parts and a much more matched set of components. |
Mblizzard |
Apr 17 2019, 10:16 AM
JOEPROPER |
Apr 17 2019, 10:23 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Not trying to drudge up old memories but im trying to learn from your experiences Can you talk about what road you went this time vs your last type 4 . You dont have to tell me your goals with these motors I can tell its to haul ass and i appreciate you staying Loyal to the /4 cause im sure this one cost /6 comversion money . amd that /6 has been hard to resist I am a fan of the 4. I know I have spent more money on this than a 6 conversion but the 4 is what I love. Overall, I have always felt there was more in the 4 than most gave it credit for. The advance in technology regarding FI and engine components (Nickies and Lens heads) has made it possible to get that performance without building an engine that is a bomb waiting to explode. I broke a 78mm crank on my last engine. It was a 2.3 with 98mm brial cylinders and Mahle pistons with a great set of big valve heads which were ported. On a very poor tune this put 115hp to the wheels. It was really fun to drive and there was still more there. I still have the components if anyone wants to go big 4 for a lower cost. So this is just the next level. This will be my last one to build so I am going all out. I think the last build was a great compromise between spending the 6 money and building a reasonably high HP 4. The build is what compromised the crank. Hard to survive when a bearing is installed incorrectly! Bad things happen! So same basic road with higher quality parts and a much more matched set of components. I can't imagine that it lasted very long... Live and learn. This next build will go better with more attention being paid. I hope. Good luck! |
Mblizzard |
Apr 17 2019, 10:32 AM
Not trying to drudge up old memories but im trying to learn from your experiences Can you talk about what road you went this time vs your last type 4 . You dont have to tell me your goals with these motors I can tell its to haul ass and i appreciate you staying Loyal to the /4 cause im sure this one cost /6 comversion money . amd that /6 has been hard to resist I am a fan of the 4. I know I have spent more money on this than a 6 conversion but the 4 is what I love. Overall, I have always felt there was more in the 4 than most gave it credit for. The advance in technology regarding FI and engine components (Nickies and Lens heads) has made it possible to get that performance without building an engine that is a bomb waiting to explode. I broke a 78mm crank on my last engine. It was a 2.3 with 98mm brial cylinders and Mahle pistons with a great set of big valve heads which were ported. On a very poor tune this put 115hp to the wheels. It was really fun to drive and there was still more there. I still have the components if anyone wants to go big 4 for a lower cost. So this is just the next level. This will be my last one to build so I am going all out. I think the last build was a great compromise between spending the 6 money and building a reasonably high HP 4. The build is what compromised the crank. Hard to survive when a bearing is installed incorrectly! Bad things happen! So same basic road with higher quality parts and a much more matched set of components. I can't imagine that it lasted very long... Live and learn. This next build will go better with more attention being paid. I hope. Good luck! Not my mistake but certainly a learning experience. |
Bills914-4 |
Apr 17 2019, 03:49 PM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Hi Mike,
Welcome to the big motors (IMG:style_emoticons/default/evilgrin.gif) , Nice list of parts , do you plan on having the bearings coated , calico coatings not to far away , I have had good success with them, I might be wrong but with that parts list , I feel you should go 1 3/4 on the exhaust system , let that that BIG motor breathe , I run the 1 7/8 system on my 2.8-4 , I'm assuming that the cam will have a reduced base circle (rod to cam clearance with that stoke & bigger rod journal ) just a heads up ?, Good luck & I'll be lookingforward to seeing it at Okteenerfest (IMG:style_emoticons/default/aktion035.gif) , Bill D. |
mb911 |
Apr 17 2019, 04:46 PM
914 Guru Group: Members Posts: 6,801 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Gonna be a monster motor.. I would love to develop an exhaust for something like that.
Mblizzard |
Apr 17 2019, 07:04 PM
Hi Mike, Welcome to the big motors (IMG:style_emoticons/default/evilgrin.gif) , Nice list of parts , do you plan on having the bearings coated , calico coatings not to far away , I have had good success with them, I might be wrong but with that parts list , I feel you should go 1 3/4 on the exhaust system , let that that BIG motor breathe , I run the 1 7/8 system on my 2.8-4 , I'm assuming that the cam will have a reduced base circle (rod to cam clearance with that stoke & bigger rod journal ) just a heads up ?, Good luck & I'll be lookingforward to seeing it at Okteenerfest (IMG:style_emoticons/default/aktion035.gif) , Bill D. Yes you are correct on the exhaust. Chris Foley had already set me straight on the exhaust size. Not familiar with the coating of bearings. Tell me more. |
Mark Henry |
Apr 17 2019, 08:00 PM
Basically you will have the same engine I have in my '67 bug. (IMG:style_emoticons/default/smile.gif)
102mm nickies, JE pistons with valve pockets and extra pin oiling holes., ARP case and head studs. 78mm DPR crank CB 5.4 rods web cam 914heads, modified by me, unshrouded 44mmX38mm SS valves, dual springs, CrMo retainers and keepers, etc... SDS FI with 55lb Siemens injectors 46mm ITB's, modified GSXR 1-3/4" A1 header for T4 into bug conversion. BTW I have a tangerine 914, 1-7/8" header/muffler hanging on my wall. (IMG:style_emoticons/default/biggrin.gif) You will have a hard time getting 9.5:1, big chambers, best I could do with a .040" deck was 9.2:1 CR or it maybe it was 9.3, but I couldn't get 9.5CR. |
Mblizzard |
Apr 18 2019, 05:59 AM
Basically you will have the same engine I have in my '67 bug. (IMG:style_emoticons/default/smile.gif) 102mm nickies, JE pistons with valve pockets and extra pin oiling holes., ARP case and head studs. 78mm DPR crank CB 5.4 rods web cam 914heads, modified by me, unshrouded 44mmX38mm SS valves, dual springs, CrMo retainers and keepers, etc... SDS FI with 55lb Siemens injectors 46mm ITB's, modified GSXR 1-3/4" A1 header for T4 into bug conversion. BTW I have a tangerine 914, 1-7/8" header/muffler hanging on my wall. (IMG:style_emoticons/default/biggrin.gif) You will have a hard time getting 9.5:1, big chambers, best I could do with a .040" deck was 9.2:1 CR or it maybe it was 9.3, but I couldn't get 9.5CR. Len is going to modify my heads to get the correct compression. |
914dave |
Apr 18 2019, 06:05 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Mike
Are you going with the one piece crankshaft design this time around? (IMG:style_emoticons/default/sunglasses.gif) |
Mblizzard |
Apr 18 2019, 07:09 AM
Mike Are you going with the one piece crankshaft design this time around? (IMG:style_emoticons/default/sunglasses.gif) The two piece arrangement did not fair very well. But the reality is that the improper installation of the bearing is what caused the crank to fail. it was apparent that the bearing was not in place and then the case was tightened down. I am sure it would not turn so they opened it up and only repositioned the bearing instead of replacing it. Small thing but after time it resulted in a broken crank. Went with the forged crank. |
thelogo |
Apr 18 2019, 07:21 AM
Mblizzard |
Apr 18 2019, 08:01 AM
I am sure it would not turn so they opened it up and only repositioned the bearing instead of replacing it. Went with the forged crank. If you dont mind me asking who is they? Who compromised the bearing/crank/motor Prefer not to post anything that I was not there to confirm. The engine had a couple of revisions so I am not going to call out anyone unless I was there to confirm. |
Mblizzard |
Apr 18 2019, 09:06 AM
Basically you will have the same engine I have in my '67 bug. (IMG:style_emoticons/default/smile.gif) 102mm nickies, JE pistons with valve pockets and extra pin oiling holes., ARP case and head studs. 78mm DPR crank CB 5.4 rods web cam 914heads, modified by me, unshrouded 44mmX38mm SS valves, dual springs, CrMo retainers and keepers, etc... SDS FI with 55lb Siemens injectors 46mm ITB's, modified GSXR 1-3/4" A1 header for T4 into bug conversion. BTW I have a tangerine 914, 1-7/8" header/muffler hanging on my wall. (IMG:style_emoticons/default/biggrin.gif) You will have a hard time getting 9.5:1, big chambers, best I could do with a .040" deck was 9.2:1 CR or it maybe it was 9.3, but I couldn't get 9.5CR. That has to be one bad bug! |
Bills914-4 |
Apr 19 2019, 05:06 PM
Hi Mike, Welcome to the big motors (IMG:style_emoticons/default/evilgrin.gif) , Nice list of parts , do you plan on having the bearings coated , calico coatings not to far away , I have had good success with them, I might be wrong but with that parts list , I feel you should go 1 3/4 on the exhaust system , let that that BIG motor breathe , I run the 1 7/8 system on my 2.8-4 , I'm assuming that the cam will have a reduced base circle (rod to cam clearance with that stoke & bigger rod journal ) just a heads up ?, Good luck & I'll be lookingforward to seeing it at Okteenerfest (IMG:style_emoticons/default/aktion035.gif) , Bill D. Yes you are correct on the exhaust. Chris Foley had already set me straight on the exhaust size. Not familiar with the coating of bearings. Tell me more. It's a performance coating for bearings , piston skirts, piston tops, It might be (would be) a worthwhile investment with this motor , have your bearings coated , piston tops coated & skirts recoated (better quality coating) I believe Len recommends having the heads (chambers & valves) done , I hope this helps Bill D. PS who is doing your timesert install for your cylinder studs ? if your doing it ,let me know I have some tools that I made to help install them below the surface, bearings - CT-1 piston skirts - CT-3 piston tops - CT-2 www.calicocoatings.com/coatings/ |
Lo-Fi Version | Time is now: 19th April 2024 - 08:40 PM |
