How to Stop this Thing, Time for a Brake Upgrade |
Mowog4 |
Apr 17 2019, 09:44 AM
Member Group: Members Posts: 286 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I finally have my car reasonably roadworthy and am working the bugs (mostly self inflicted) out of the build. The car is a wide body, so wide tires and 17” rims. I am running 300 whp, out of a Wrx eng/trans combo. The car has 911 front suspension and brakes and 911 rear rotors with 914 PMB rebuilt calipers.
I need better brakes. I have tried doing a search, but typing in brakes yields lots of results. I was thinking of changing out to Boxster, but thought I would pulse the group first. Thanks Ed |
mepstein |
Apr 17 2019, 09:52 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Do you have 3" or 3.5" struts?
3" = M calipers or Brembo aluminum calipers from an Alfa Romeo 3.5" = SC, Carrera, S calipers, Boxster (with adaptors), ect. |
Mowog4 |
Apr 17 2019, 10:34 AM
Mblizzard |
Apr 17 2019, 10:57 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I finally have my car reasonably roadworthy and am working the bugs (mostly self inflicted) out of the build. The car is a wide body, so wide tires and 17” rims. I am running 300 whp, out of a Wrx eng/trans combo. The car has 911 front suspension and brakes and 911 rear rotors with 914 PMB rebuilt calipers. I need better brakes. I have tried doing a search, but typing in brakes yields lots of results. I was thinking of changing out to Boxster, but thought I would pulse the group first. Thanks Ed Quick suggestion - Call Eric at PMB Performance https://www.pmbperformance.com/ |
mepstein |
Apr 17 2019, 11:38 AM
Do you have 3" or 3.5" struts? 3" = M calipers or Brembo aluminum calipers from an Alfa Romeo 3.5" = SC, Carrera, S calipers, Boxster (with adaptors), ect. I’ll as a Stupid question, how do I know which ones they are? Do you know what year 911 they came from? Measure the caliper mounting holes, center to center. |
Mowog4 |
Apr 17 2019, 01:20 PM
Do you have 3" or 3.5" struts? 3" = M calipers or Brembo aluminum calipers from an Alfa Romeo 3.5" = SC, Carrera, S calipers, Boxster (with adaptors), ect. I’ll as a Stupid question, how do I know which ones they are? Do you know what year 911 they came from? Measure the caliper mounting holes, center to center. Don’t know the year, believe it is early 70’s. I only had a tape measure, bu the center to center measurement was 3-1/2”. |
jcd914 |
Apr 17 2019, 03:05 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
What are you doing with the car that the 911 brakes you have are enough?
The 3 1/2 center to center are the later 911 struts from 74 to 87 911 SC/Carrera. The 911 calipers should be able to lock up the wheels even with wide tires and wheels. If not then you have an issue with the brake working correctly not being undersized. If you are tracking the car and the brakes are fading from use after a few laps that is a different issue. Of course putting bigger brakes on doesn't hurt and has it's own cool factor. Jim |
Mowog4 |
Apr 17 2019, 04:02 PM
What are you doing with the car that the 911 brakes you have are enough? The 3 1/2 center to center are the later 911 struts from 74 to 87 911 SC/Carrera. The 911 calipers should be able to lock up the wheels even with wide tires and wheels. If not then you have an issue with the brake working correctly not being undersized. If you are tracking the car and the brakes are fading from use after a few laps that is a different issue. Of course putting bigger brakes on doesn't hurt and has it's own cool factor. Jim The brakes are in very good shape, new rotors, rebuilt calipers, new master cylinder. I was “exercising” the car in in a canyon with lots of twisties. Brakes are great at slow speeds but get overpowered . My brother has an ‘85 SC, my car is much faster. I am 57, the cool factor doesn’t really come in to play. Ed |
Chris914n6 |
Apr 17 2019, 04:59 PM
Jackstands are my life. Group: Members Posts: 3,307 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
914s are 7-800 lbs lighter than a 911. It's not the rotors & calipers.
pads? 19mm master cylinder? |
mepstein |
Apr 17 2019, 05:52 PM
914s are 7-800 lbs lighter than a 911. It's not the rotors & calipers. pads? 19mm master cylinder? (IMG:style_emoticons/default/agree.gif) The brakes on the car should be more than enough. Make sure the whole system is up to snuff, pads bedded in and all the soft lines are new. |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:39 AM |
