How to Stop this Thing, Time for a Brake Upgrade |
Mowog4 |
Apr 17 2019, 09:44 AM
Member Group: Members Posts: 290 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I finally have my car reasonably roadworthy and am working the bugs (mostly self inflicted) out of the build. The car is a wide body, so wide tires and 17” rims. I am running 300 whp, out of a Wrx eng/trans combo. The car has 911 front suspension and brakes and 911 rear rotors with 914 PMB rebuilt calipers.
I need better brakes. I have tried doing a search, but typing in brakes yields lots of results. I was thinking of changing out to Boxster, but thought I would pulse the group first. Thanks Ed |
jcd914 |
Apr 17 2019, 03:05 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
What are you doing with the car that the 911 brakes you have are enough?
The 3 1/2 center to center are the later 911 struts from 74 to 87 911 SC/Carrera. The 911 calipers should be able to lock up the wheels even with wide tires and wheels. If not then you have an issue with the brake working correctly not being undersized. If you are tracking the car and the brakes are fading from use after a few laps that is a different issue. Of course putting bigger brakes on doesn't hurt and has it's own cool factor. Jim |
Mowog4 |
Apr 17 2019, 04:02 PM
What are you doing with the car that the 911 brakes you have are enough? The 3 1/2 center to center are the later 911 struts from 74 to 87 911 SC/Carrera. The 911 calipers should be able to lock up the wheels even with wide tires and wheels. If not then you have an issue with the brake working correctly not being undersized. If you are tracking the car and the brakes are fading from use after a few laps that is a different issue. Of course putting bigger brakes on doesn't hurt and has it's own cool factor. Jim The brakes are in very good shape, new rotors, rebuilt calipers, new master cylinder. I was “exercising” the car in in a canyon with lots of twisties. Brakes are great at slow speeds but get overpowered . My brother has an ‘85 SC, my car is much faster. I am 57, the cool factor doesn’t really come in to play. Ed |
Lo-Fi Version | Time is now: 17th May 2024 - 06:44 PM |
