Cylinder Head Washers, Anything special about them? |
bbrock |
Apr 17 2019, 11:05 AM
The washers I took off my heads (Type 4) 30 years ago got mixed in with my other hardware. I fished out 16 M10 washers that fit, but want to make sure I'm installing correct washers and maybe source some new ones if needed. PET just lists:
washer A 10,5 Are they special thickness or hardness etc.? BTW, anyone know what the "A", "B", etc. for hardware specs in the PET mean? I haven't been able to find a key. Must be looking in the wrong place. |
Valy |
Apr 17 2019, 11:21 AM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Yes, they are harder than regular washers.
You need to use the correct ones or they will smash and bad things can happen. |
bbrock |
Apr 17 2019, 11:25 AM
Yes, they are harder than regular washers. You need to use the correct ones or they will smash and bad things can happen. Thank you! Exactly what I would have guessed. Would these from Belmetric work? https://www.belmetric.com/hardened-metric-f...in-p-10688.html |
Mblizzard |
Apr 17 2019, 11:34 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Yes, they are harder than regular washers. You need to use the correct ones or they will smash and bad things can happen. Thank you! Exactly what I would have guessed. Would these from Belmetric work? https://www.belmetric.com/hardened-metric-f...in-p-10688.html If you can't find let me know I have a new set I can send you for free. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:50 PM |
