Cylinder Head Washers, Anything special about them? |
bbrock |
Apr 17 2019, 11:05 AM
The washers I took off my heads (Type 4) 30 years ago got mixed in with my other hardware. I fished out 16 M10 washers that fit, but want to make sure I'm installing correct washers and maybe source some new ones if needed. PET just lists:
washer A 10,5 Are they special thickness or hardness etc.? BTW, anyone know what the "A", "B", etc. for hardware specs in the PET mean? I haven't been able to find a key. Must be looking in the wrong place. |
Valy |
Apr 17 2019, 11:21 AM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Yes, they are harder than regular washers.
You need to use the correct ones or they will smash and bad things can happen. |
bbrock |
Apr 17 2019, 11:25 AM
Yes, they are harder than regular washers. You need to use the correct ones or they will smash and bad things can happen. Thank you! Exactly what I would have guessed. Would these from Belmetric work? https://www.belmetric.com/hardened-metric-f...in-p-10688.html |
Mblizzard |
Apr 17 2019, 11:34 AM
Yes, they are harder than regular washers. You need to use the correct ones or they will smash and bad things can happen. Thank you! Exactly what I would have guessed. Would these from Belmetric work? https://www.belmetric.com/hardened-metric-f...in-p-10688.html If you can't find let me know I have a new set I can send you for free. |
bbrock |
Apr 17 2019, 12:16 PM
Yes, they are harder than regular washers. You need to use the correct ones or they will smash and bad things can happen. Thank you! Exactly what I would have guessed. Would these from Belmetric work? https://www.belmetric.com/hardened-metric-f...in-p-10688.html If you can't find let me know I have a new set I can send you for free. Thanks for the generous offer! I'll take you up on it. I just measured one of the washers I have which I'm pretty sure was an actual head washer. It is both thicker and larger O.D. than the Belmetric ones. Given the critical nature of this part, I'd rather not make guesses. I'll PM you. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:13 PM |
