Low oil pressure - oil pump a workable fix? |
Tdskip |
Apr 18 2019, 02:21 PM
Yeah, yeah, I know. It's not likely the oil pump but humor me.
The red aka turbo car is showing low oil pressure. It has a front mounted oil cooler and some sort of big bore engine. Oil level is full cold and when hot. When cold my oil pressure is good, when hot it isn't. I'm under 10 PSI per 1000 RPM hot. I don't have a history on the engine. I am running 20w50, Mahle filter. I have not put a mechanical gauge on it but it is already running a retrofitted VDO oil pressure gauge. Goal is to get another summer out of driving it if I can. I supposed it wouldn't hurt to try a mechanical gauge and heavier weight oil, but is there a chance it is the oil pump rather than bearings? |
sixnotfour |
Apr 18 2019, 02:40 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pull the sump screen and run your finger around in the case , hope you done get a sliver
Lo-Fi Version | Time is now: 15th May 2024 - 10:49 AM |
