Low oil pressure - oil pump a workable fix? |
Tdskip |
Apr 18 2019, 02:21 PM
Yeah, yeah, I know. It's not likely the oil pump but humor me.
The red aka turbo car is showing low oil pressure. It has a front mounted oil cooler and some sort of big bore engine. Oil level is full cold and when hot. When cold my oil pressure is good, when hot it isn't. I'm under 10 PSI per 1000 RPM hot. I don't have a history on the engine. I am running 20w50, Mahle filter. I have not put a mechanical gauge on it but it is already running a retrofitted VDO oil pressure gauge. Goal is to get another summer out of driving it if I can. I supposed it wouldn't hurt to try a mechanical gauge and heavier weight oil, but is there a chance it is the oil pump rather than bearings? |
jcd914 |
Apr 18 2019, 06:06 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Test, don't guess.
Test the pressure with a gauge you know to be accurate. Then if it does really have low oil pressure look at possible causes before you condemn the engine outright. A stuck oil pressure relief valve that does not seat well could create the symptoms you are seeing. Chris at Tangerine Racing makes a replacement oil pressure relief valve that addresses the poor seating problem these cases and relief valves have. Jim |
Tdskip |
Apr 18 2019, 06:11 PM
Test, don't guess. Test the pressure with a gauge you know to be accurate. Then if it does really have low oil pressure look at possible causes before you condemn the engine outright. A stuck oil pressure relief valve that does not seat well could create the symptoms you are seeing. Chris at Tangerine Racing makes a replacement oil pressure relief valve that addresses the poor seating problem these cases and relief valves have. Jim Well that seems like good advice - let me get a gauge on it. How do you confirm if the oil pressyre relief valve is an issue? |
jcd914 |
Apr 18 2019, 06:24 PM
Test, don't guess. Test the pressure with a gauge you know to be accurate. Then if it does really have low oil pressure look at possible causes before you condemn the engine outright. A stuck oil pressure relief valve that does not seat well could create the symptoms you are seeing. Chris at Tangerine Racing makes a replacement oil pressure relief valve that addresses the poor seating problem these cases and relief valves have. Jim Well that seems like good advice - let me get a gauge on it. How do you confirm if the oil pressyre relief valve is an issue? It is a bit subjective but if the pressure is low I would pull the pressure reilif valve and inspect ir and the bore and seating surface in the case. There is a machines step in the bore in the case that is not always in good shape. You may be able clean the bore of the oil and and see wear marks where the valve seats and evaluate if it is seating well or not. You may need ot use some bluing or dye to see the seating surfaces and evaluate the seal. Also the bore waers and the relief valve can stick in the bore so it does not move as intended. Jim |
Lo-Fi Version | Time is now: 15th May 2024 - 05:42 PM |
