Low oil pressure - oil pump a workable fix? |
Tdskip |
Apr 18 2019, 02:21 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Yeah, yeah, I know. It's not likely the oil pump but humor me.
The red aka turbo car is showing low oil pressure. It has a front mounted oil cooler and some sort of big bore engine. Oil level is full cold and when hot. When cold my oil pressure is good, when hot it isn't. I'm under 10 PSI per 1000 RPM hot. I don't have a history on the engine. I am running 20w50, Mahle filter. I have not put a mechanical gauge on it but it is already running a retrofitted VDO oil pressure gauge. Goal is to get another summer out of driving it if I can. I supposed it wouldn't hurt to try a mechanical gauge and heavier weight oil, but is there a chance it is the oil pump rather than bearings? |
Tdskip |
May 3 2019, 06:23 PM
Thanks George.
To install a mechanical oil gauge to test the oil pressure I simply remove the oil pressure sender in the taco plate? Thanks! |
Dave_Darling |
May 3 2019, 10:49 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
To install a mechanical oil gauge to test the oil pressure I simply remove the oil pressure sender in the taco plate? No. The sender in the taco plate is oil temp, not oil pressure. WOuldn't do any good to measure pressure there, it would always be zero. (The oil is just sitting there in the sump; you need to measure it in one of the oil passages that has been pressurized by the pump.) The usual way to hook up an oil pressure gauge is to replace the oil pressure "idiot light" sender that lives near the distributor on top of the crankcase. --DD |
Tdskip |
May 3 2019, 11:06 PM
To install a mechanical oil gauge to test the oil pressure I simply remove the oil pressure sender in the taco plate? No. The sender in the taco plate is oil temp, not oil pressure. WOuldn't do any good to measure pressure there, it would always be zero. (The oil is just sitting there in the sump; you need to measure it in one of the oil passages that has been pressurized by the pump.) The usual way to hook up an oil pressure gauge is to replace the oil pressure "idiot light" sender that lives near the distributor on top of the crankcase. --DD Oops! Thanks for putting me straight on that Dave. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:22 AM |
