Low oil pressure - oil pump a workable fix? |
Tdskip |
Apr 18 2019, 02:21 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Yeah, yeah, I know. It's not likely the oil pump but humor me.
The red aka turbo car is showing low oil pressure. It has a front mounted oil cooler and some sort of big bore engine. Oil level is full cold and when hot. When cold my oil pressure is good, when hot it isn't. I'm under 10 PSI per 1000 RPM hot. I don't have a history on the engine. I am running 20w50, Mahle filter. I have not put a mechanical gauge on it but it is already running a retrofitted VDO oil pressure gauge. Goal is to get another summer out of driving it if I can. I supposed it wouldn't hurt to try a mechanical gauge and heavier weight oil, but is there a chance it is the oil pump rather than bearings? |
porschetub |
May 4 2019, 03:04 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Best to do it with engine hot as that is what really matters,what pressure did you get @ say 3k rpm with the oil cold.
Edit didn't see your next reply....that isn't good oil pressure (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 08:13 AM |
