Low oil pressure - oil pump a workable fix? |
Tdskip |
Apr 18 2019, 02:21 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Yeah, yeah, I know. It's not likely the oil pump but humor me.
The red aka turbo car is showing low oil pressure. It has a front mounted oil cooler and some sort of big bore engine. Oil level is full cold and when hot. When cold my oil pressure is good, when hot it isn't. I'm under 10 PSI per 1000 RPM hot. I don't have a history on the engine. I am running 20w50, Mahle filter. I have not put a mechanical gauge on it but it is already running a retrofitted VDO oil pressure gauge. Goal is to get another summer out of driving it if I can. I supposed it wouldn't hurt to try a mechanical gauge and heavier weight oil, but is there a chance it is the oil pump rather than bearings? |
Tdskip |
May 3 2019, 03:18 PM
So I picked up a replacement oil pressure relief spring, from what I’ve learned from you all it’s probably not a bad thing to have on hand anyway.
I believe the cover for this is located next to the oil filter on the bottom of the engine, correct? Will this cover and screw readily with just a long screwdriver or do I need to remove the oil filter to get better access? Not my car but I believe this is what the cover looks like, correct? Thanks! |
76-914 |
May 5 2019, 08:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
So I picked up a replacement oil pressure relief spring, from what I’ve learned from you all it’s probably not a bad thing to have on hand anyway. I believe the cover for this is located next to the oil filter on the bottom of the engine, correct? Will this cover and screw readily with just a long screwdriver or do I need to remove the oil filter to get better access? Not my car but I believe this is what the cover looks like, correct? Thanks! This (1/2" drive) tool is your ticket. The snap-on number can probably be cross referenced. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 12:16 AM |
