Plug wire, spark plugs and dwell, New info on post 24 |
VaccaRabite |
Apr 18 2019, 04:02 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So my car starts bucking again on todays shakedown cruise (and with the PA roads this spring it is REALLY SHAKING!). I pull back home guessing the #3 lead came off again. With the car running I touch the lead pull it off the #3 plug. While I'm doing this the plug wire is shocking the hell out of me!
Like an idiot I stand there looking at it (as it continues to shock the hell out of me) until I drop it and I hear it arcing against something in the engine bay. I turn off the car and remove the entire lead (I have coil near plug, the lead is only about 6 inches long). Flexing it all over, I can't find ANY breaks in the insulation. these leads are almost brand new, and only have about 200 miles on them. They are very flexible and the insulation seems to be in great shape. The pulse was jumping through the insulation on the wire and arcing against the powdercoated #3 intake runner, causing the bucking. The coil pack is certainly strong! I moved the wire as far as I could from the intake runner (the pack is bolted right next to the intake runners, so I can only move it so far) and the car ran flawlessly. I went on a 30 minute drive and it was AWESOME. So... what next. On a wet day its going to be arcing everywhere. I've sat through that ride before. Maybe make new leads with thicker plug wires? Do I need spiral wound? @mcmark @spoke |
VaccaRabite |
Apr 21 2019, 08:18 AM
High power coil packs, one per cylinder, with about a 6 inch lead going to the spark plug.
I have a GT grill with no rain tray. When I was using carbs I needed all the cool air I could get to keep the engine in line. Longer drives are needed, but I may be able to go back to a standard engine lid now. Zach |
JamesM |
Apr 29 2019, 11:30 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Given you are running Megasquirt, I am wondering if you might have an issue with your ignition output settings, to much dwell cranking up the coil output to far perhaps?
I haven't personally run them, but I recall reading conflicting information as to what the dwell setting for those LS coils should be set to and I believe I saw the recommended setting for those change recently. May want to double check. High power coil packs, one per cylinder, with about a 6 inch lead going to the spark plug. I have a GT grill with no rain tray. When I was using carbs I needed all the cool air I could get to keep the engine in line. Longer drives are needed, but I may be able to go back to a standard engine lid now. Zach |
Lo-Fi Version | Time is now: 17th May 2024 - 05:48 PM |
