Plug wire, spark plugs and dwell, New info on post 24 |
VaccaRabite |
Apr 18 2019, 04:02 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So my car starts bucking again on todays shakedown cruise (and with the PA roads this spring it is REALLY SHAKING!). I pull back home guessing the #3 lead came off again. With the car running I touch the lead pull it off the #3 plug. While I'm doing this the plug wire is shocking the hell out of me!
Like an idiot I stand there looking at it (as it continues to shock the hell out of me) until I drop it and I hear it arcing against something in the engine bay. I turn off the car and remove the entire lead (I have coil near plug, the lead is only about 6 inches long). Flexing it all over, I can't find ANY breaks in the insulation. these leads are almost brand new, and only have about 200 miles on them. They are very flexible and the insulation seems to be in great shape. The pulse was jumping through the insulation on the wire and arcing against the powdercoated #3 intake runner, causing the bucking. The coil pack is certainly strong! I moved the wire as far as I could from the intake runner (the pack is bolted right next to the intake runners, so I can only move it so far) and the car ran flawlessly. I went on a 30 minute drive and it was AWESOME. So... what next. On a wet day its going to be arcing everywhere. I've sat through that ride before. Maybe make new leads with thicker plug wires? Do I need spiral wound? @mcmark @spoke |
McMark |
Apr 30 2019, 09:36 AM
They're LS2 style coils. I think the LS1 vs LS2 is an oversimplification of the variety of LS coils that are available. But there is one critical difference between LS1 coils and all the newer 'LS2' coils -- the wiring is different.
I've tried multiple times to narrow in on proper dwell for these coils, but I always come back to the idea that because of variances in production methods and quality you have to test and set the dwell for each setup. But that's my typical overthinking I suppose. Realistically, you can lower the dwell a bit and see if it helps the arcing, as well as evaluate if there are any power decrease or smooth-ness decrease. If a lower dwell helps the problem and doesn't have any negative side affects, go ahead and run it. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:32 PM |
