Plug wire, spark plugs and dwell, New info on post 24 |
VaccaRabite |
Apr 18 2019, 04:02 PM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So my car starts bucking again on todays shakedown cruise (and with the PA roads this spring it is REALLY SHAKING!). I pull back home guessing the #3 lead came off again. With the car running I touch the lead pull it off the #3 plug. While I'm doing this the plug wire is shocking the hell out of me!
Like an idiot I stand there looking at it (as it continues to shock the hell out of me) until I drop it and I hear it arcing against something in the engine bay. I turn off the car and remove the entire lead (I have coil near plug, the lead is only about 6 inches long). Flexing it all over, I can't find ANY breaks in the insulation. these leads are almost brand new, and only have about 200 miles on them. They are very flexible and the insulation seems to be in great shape. The pulse was jumping through the insulation on the wire and arcing against the powdercoated #3 intake runner, causing the bucking. The coil pack is certainly strong! I moved the wire as far as I could from the intake runner (the pack is bolted right next to the intake runners, so I can only move it so far) and the car ran flawlessly. I went on a 30 minute drive and it was AWESOME. So... what next. On a wet day its going to be arcing everywhere. I've sat through that ride before. Maybe make new leads with thicker plug wires? Do I need spiral wound? @mcmark @spoke |
VaccaRabite |
May 13 2019, 12:04 PM
So a bunch of things have been coming to mind lately on this issue.
I was driving the car between rainstorms Saturday, pushing it pretty hard since it was having a "good running" day. It occured to me that my issues could be the spark plugs. When I'm having issues, its while I'm driving the car around town or with the kids in it, and the engine is running cool to cold (head temps around 250 - temps on this engine rarely get above 330 even climbing hills on the highway in 5th). I am thinking that the root of the problem may be that I need one range hotter plug, and my plugs are just fouling around town, never getting hot enough to go into self cleaning mode. I'm running NKG BP6ES plugs, and just bought a set of BP5ES plugs (one range hotter for NKG). my thinking is that these may go into self cleaning mode a little easier, and won't load up as much driving around town or taking my son to scouts, etc. This is plug 4. Keep in mind it only has a few hundred miles on it. It seems to me to be ok to cold. And this was after driving the car pretty hard for an hour, and then taking a slightly more sedate cruise home via wet back roads. Yes, my car is tuned rich. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1557770670.1.jpg) I know its hard to read plugs with modern fuels. Next issue. My car's tune has the dwell set to 6.2ms and not the 3.5ms that is currently suggested in the megamanual. right now I only want to change one thing at a time and new plugs will be here Wednesday. Is it safe running that dwell, or am I doing to overheat my LS2 coils. Each plug has its own coil pack. Finally, the Magnecore custom wires are getting made up. My current (ba-da tsss!) thinking has me on a path that the wires really aren't the issue, but I'll have the nice new ones. Zach |
Frank S |
May 22 2019, 04:04 PM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi Zach,
with Megasquirt I think you should use the NGK BPR6ES or BPR5ES. B.R. Frank So a bunch of things have been coming to mind lately on this issue. I was driving the car between rainstorms Saturday, pushing it pretty hard since it was having a "good running" day. It occured to me that my issues could be the spark plugs. When I'm having issues, its while I'm driving the car around town or with the kids in it, and the engine is running cool to cold (head temps around 250 - temps on this engine rarely get above 330 even climbing hills on the highway in 5th). I am thinking that the root of the problem may be that I need one range hotter plug, and my plugs are just fouling around town, never getting hot enough to go into self cleaning mode. I'm running NKG BP6ES plugs, and just bought a set of BP5ES plugs (one range hotter for NKG). my thinking is that these may go into self cleaning mode a little easier, and won't load up as much driving around town or taking my son to scouts, etc. This is plug 4. Keep in mind it only has a few hundred miles on it. It seems to me to be ok to cold. And this was after driving the car pretty hard for an hour, and then taking a slightly more sedate cruise home via wet back roads. Yes, my car is tuned rich. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1557770670.1.jpg) I know its hard to read plugs with modern fuels. Next issue. My car's tune has the dwell set to 6.2ms and not the 3.5ms that is currently suggested in the megamanual. right now I only want to change one thing at a time and new plugs will be here Wednesday. Is it safe running that dwell, or am I doing to overheat my LS2 coils. Each plug has its own coil pack. Finally, the Magnecore custom wires are getting made up. My current (ba-da tsss!) thinking has me on a path that the wires really aren't the issue, but I'll have the nice new ones. Zach |
VaccaRabite |
May 23 2019, 07:14 AM
Frank S |
May 23 2019, 03:22 PM
Hi Zach, with Megasquirt I think you should use the NGK BPR6ES or BPR5ES. Hey @Frank_S I just installed a set of NKG BP5ES plugs. I'm not sure what the R would signify. Resistor? Zach Hi Zach, yes, resistor type. I'm just about to upgrade my engine with Megasquirt and the resistor spark plugs were strongly recomended to me as the standard spark plugs could generate to much noise. Cheers, Frank |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:54 AM |
